You can just replace the wires, just need to splice in some new ones. From what I've heard the stock coils are very reliable so I left mine and did the wires.
I used the same coils but you'll need to modify the stock Coil brackets to fit them under the tank.
I used Aluminum Angle Stock but if I had it to do again I'd use Flat Stock as the Down Angle part just got in the way of bolting the coil in place.
Note: I also modified the Condensor mounting bracket to a vertical mount for clearance.
I made up a adapter connector so I didn't have to cut the stock wiring harness. See last pic. The bullet Connectors and 3 way connector were from VintageConnections.com ( 3.5 mm bullet connectores get the crimp tool it makes a difference.
