Coils
  • Thread starter Thread starter jryftc
  • Start date Start date
J
jryftc
Guest
Is it possible for a coil to be "good" (providing enough power to fire all cylinders), but not as strong as it should be. I recently replaced a coil on a 4 cylinder bike, and noticed a small amount of arching between the points on the other coil I didn't replace. I notice my acceleration isn't as good as it should be, and is popping at times. I just went through the carbs like very well, so I feel as though it isn't that anymore. It makes me think it may be valve adjustments (which I should have done first I guess), or something electrical..
If the points are arcing, it is most likely the condenser is bad.
Only one point is arching on the 1-4 coil. Still replace a condenser?
There are 2 condensers, one for each set of points. I'd replace both as they are probably old and the are cheap enough.
