Compact Battery for a Cafe?
dirtbag said:
Sounds to me like we're gonna have a few bike fires this year and next.
looks like it's a possibility :D ;)
You need to know the maximum charge/discharge rate of battery.
If amperage trying to charge it is too high, it will explode.
You wouldn't connect battery to an arc welder, most charging systems will provide around a 20amp 'spike' as regulator 'switches' on and off. (more on an EMF system)
The voltage is pretty irrelevant
If you don't know what your doing, don't go smaller than 75% of stock size
No, but you can arc weld (very nicely at that) using only a battery. Just hook the battery up to the stick (leave the actual welder out). ;D Sorry, 2am.
Just received a response from the guys over at Maviryk batteries and this is what he wrote me about my CB750:
"Hi Ryan,
Sorry for my delayed reply. I've been out of the office for Thanksgiving. The MD8 should be perfect for your application. It has 240 CA and 4.6AH and will not boil. Does your charging system still cut off at 14.5-15V? Dimensions of the MD8 are 2.25"x4.25"x3", not including the quick-connects."
Questions for you guys now. He asked me if my charging system still cuts off at 14.5-15V. What does this mean? Thanks.
I hope this helps the topic starter's question!
