compression cb650?
stein514
I recently bought a '79 cb650 and finally got it somewhat tuned. but now I find oil coming from #2 cylinder where the head gasket sits. once the engine is warm, it also likes to smoke out the muffler and the valve covers. I did a compression test, since it seems to be lacking power when letting go of the clutch in 1st gear and it wants to stall. the results of the compression test were 140, 130, 140, and 140, respectively (with choke opened as it stated in the compression test kit manual). Are those good values? #2 spark plug shows burnt oil, and so is #4. any advice or ideas on where to begin? will i just need to replace the gaskets? I can't find info on the compression it's supposed to have. ???
I guess I will take the engine apart. fortunately I got the Arethna gasket set with my purchase. just too bad I already have to use it. The manual says I can take off the cylinder head without taking engine off the bike. would it be better to take the engine off anyways or doesn't it matter?
your compression figures aren't bad,,,#2 and #4,,,share the same coil, are your plugs shiney black,,or soot black.....(carbon)
spark plugs #2 and 4 are more shiny black, and #1 and 3 are kinda white, assuming that they run a little too hot. the engine is definitely burning some oil, probably sucking it through the valves. Therefore new gaskets and adjustments. The carbs need some serious adjusting. what's the best way to go about that. back to factory settings and then a half turn-up-kinda deal? how would I go about synchronizing them?
