Yeh the horn itself definately works - If I bridge the connectors in the plug so that it gets power, it does it's job, but the button in the switch does nothing.
The horn button just grounds the wire. If you handlebars are not grounded the button can't work. Make sure you handlebars are wired to ground. The mounts are rubber, so a separate wire is needed
Sent from planet Earth using mysterious electronic devices and Tapatalk
