Converting media blaster pot into soda blaster ???
timdhawk
I have a 110 lb blaster from HF. This guy: http://images.harborfreight.com/cpi/photos/95000-95099/95014.gif
Eastwood sells a "conversion kit" for $130.00 :o :o :o http://www.eastwood.com/soda-blasting-retro-fit-kit.html# that doesn't look like more than $15-$20 worth of brass fittings and hose.
I understand that for running soda in a media blaster there needs to be a restrictor (i think). Has anyone figured out the trick to do this w/o having to dump the bank on a conversion kit.
Speculation okay, but hard knowledge would be helpful. thanks.
why such a big blaster? i got the 20 pound blaster... should be plenty big enough for doing one project at a time.
im interested in the conversion kit also... for the same reason; engine cases.
I got a spot blaster from JCWhitney a couple years ago and it works great. It's a gravity fed handheld unit with a 1 pound plastic container on top. Think it was like $40 or something.
I already had the big one, I used/got it for my frame and wheels. Plus it was on sale and i had a 20% off coupon and got it for less than the cost of the smaller ones. now i just want to convert it for my cases.
makes sense.
what media did you use on the frame? also, how much of it do you think you went through?
