Corey's CB360 bobber build
motofiaccone said:
That wiring diagram looks good to me, but I would put a relay between the ignition switch and the battery. Putting that much current through a switch is a lot to ask. Of course, you can get high load switches, but I always question those.
--Chris
Thanks thats a good idea.
Well I didn't get too much done today. I got the starter relay and cable taken out. I tried to take the starter off but stripped two of the screws so that was a no go. I tried heating them up and was using my impact driver but still wouldn't budge. Oh well I don't have any block off plate yet anyway so that can wait for a later day. I bent up a little bracket to hold the front brake drum in place. After that I just started in on cutting tabs off the frame that I won't need anymore. I still have to make the brake hub bracket look better and get some different hardware, I just used some bolts out of my cup of extra parts from the tear down... ;D Oh and I also put on a set of my CL pipes to see how they would look. I'm considering using them and having them coated or something and then using part of the heat shield. Either that or I will end up wrapping them.
Dude, that brake stay doesn't look very safe...even if it was 3/16" steel. I mean this with the best intentions--seriously. A better solution would be to make a U-bracket that goes on each side of the hub. Then weld a 1/8" minimum steel strip to that.
I really might be wrong, but that looks like hardware store aluminum. If it is, that stuff is very fragile and not at all appropriate for stressed applications. Put it this way, I used that stuff to bend and make a license plate holder. I also welded on another tab. That material lasted about 6 miles before it snapped off.
--Chris
--Chris
Ok looks like back to the drawing board on that one then... I'm not sure what you mean by the U bracket, could you explain that a little more for me?
Hey man:
I really hope that didn't upset you. I think you'd agree though that it's better to find out now than later on down (on) the road. Still, I know how it feels to make something and find out I pissed away time an materials.
Have a look here. I personally think stainless will look best. You can likely find thick walled square tube that you can cut into a U-bracket. Then just weld it to the strap. Personally, I would drill a 5/16" hole in the strap and fill that round with weld as well. I would also use TIG, but that's me.
Please just consider this as another POSSIBLE solution.
--Chris
Oh no I wasn't upset at all and it was just some scrap I had laying around and only took 5 minutes to make. You were right it did have a fair amount of flex in it. I went out and remade it out of 3/16" steel and it is much stronger now. I see what you were saying now to about having it on both sides of the part of the hub. I may try that if this isn't strong enough. I also mounted up a fender to the rear to see how that would look.
CThor said:
I could be wrong on this because I'm not familiar with that particular brake, but it looks like you have that bracket mounted through where the cable stop is for the brake cable...in other words, the brake cable goes through where that bracket is mounted to give it something to pull against to actuate the arm. See the position of the arm where the wheel sits? that looks wrong...
maybe if you could tell us what the brake is off of I could help more...one thing for sure is that it's not a CB/CL 360 brake. They're totally different.
You are right, I was looking more into that tonight. I'm going to order a cable from an XL250 and go from there. I'll have to figure out a way for them both to work. I'm not sure if I could have the cable go through the bracket too or not. That is just the only thing on the hub that I could use to hold it in place. It looks like on the XL250 it came off of, it just sits up against the fork and that holds it in place.
Very interesting Cory. Intrigued to watch you work through this and pave the way. So cool that we all have each others back too. I got so much help on my build its not even funny. Couldn't have done mine without the DTT crew. Glad you seem to be getting the same ;D.
As far as the hub goes once its gets worked out we all will be switching to the XL 250 wheel. Awesome stuff! Keep at it.
Here ya go Troy I got my girlfriend to take a few pics of me sitting on it. This is with only one shock on it and on the lowest setting. I also had her sit on it for a couple measurements which she wasn't too excited about. She said "you want me to sit on it without a seat on it?" ;D
With her on it and one spring the shock was right at 11" so that was perfect for me to see how it would be with the 11" shocks on it. She didn't want to be in any pics though... lol
This bike is really great man. Youve done some great work so far! We have a p.o.s. wannabe chopper CB360 waiting in the wings that will be headed in this direction very soon. The frames fucked though, so Ill probobly have to find another.
forcefanajd said:
those front forks need to be slid up in the triples a good 1"-2" to level the ride out
One thing I'm wondering though is how far I'd actually be able to slide the forks up with the bigger wheel up front now. Assuming the tire I get has the same profile as the original it will be 1.5" taller than the stock wheel.
Just put in a heavier fork oil or progressive springs to work the wheel travel. Itll make the ride a little rougher, but sacrifice in the name of progress is no sacrifice at all.
Good idea, I'll have to put some heavier oil on there. Anyone have a link or name of a place to get different springs for the front? If possible I'd rather get shorter springs in there than have the fork tubes sticking way out the top.
Ya cant just throw shorter springs in I dont believe... You would have to have the tubes cut down. It can be done, but its not super cheap.
Killer stance Cory. Just be real careful with clearances and take lots of measurements. You will need to cut down the brake arm a bit when the time comes. It will need a short throw. Once you are ready, adjust it so it sits as high as it can (kinda like it is in the photos well above the peg) then cut it down and reweld the foot.
Progressive springs are a couple of inches shorter. Hit Woody up and ask where he got his. The shorter springs will limit travel but for general road riding I would figure you'd have no problems.
