Corey's CB360 bobber build
Here's a few more pics with the light tucked in a little more. I think thats where it will end up. Just need to make a more solid bracket now.
personally i like the one below... i think it looks better and gives more shape to the front end, wit the light tucked in it just looks to much like a tracker front end w/o a light.
CB looks great man!
Are you stuck on the acorn headlight? To me it looks like it's just a little too small for the bike. I think a slightly larger headlight would fit better, just my opinion...
I have a bit larger of a harley headlight i would be willing to trade you... same style as the one i used on my wifes bike
here is a pic
i used it on this build as well, got a french trim ring, then powdered both to match for this bike
What size is that light Joe?
I've kind of gone back on forth on the size of it too. I knew I didn't want the stock 7" one so I got a smaller one. I also think it looks different in person that the pictures. I sit and look at the pics and debate on the size, but when I go out and look at it on the bike then I like it... ::)
I like your headlight... looks like a good size to me. Could you drill a hole in either the top triple tree or the bottom one and mount it that way? How far out in front of the bike do you want it?
Ronin said:
I'm sure you have already thought of this...Just trying to help.
That is actually what I was thinking about doing. For now I made a new piece like the aluminum one I was mocking up with except it is made out of a thicker piece of stainless. I'll see how that holds up and if not good enough I'll go with this design instead.
I ended up making it like the picture Joe said he liked the best. I decided he was right and it looked better sticking out a little as opposed to tucked into the top tree.
I've been looking around for a mini speedo. I'm just not sure which ones will work correctly especially now with the bigger front tire. Any help would be appreciated.
Ronin said:
What about the speedometer from the bike where you got the tire?
I just bought that wheel from ebay... I can do some more research and see if I can find the ratio of the speedo on the XL250.
You probably just need the speedometer drive cable from that bike then it should work on any standard japanese speedometer ratio which is 2240rpm=60mph.
My new front brake cable came today along with my new throttle assembly and grips. Brake cable is on and working, might still need some fine tuning though. The throttle (tube clamp?) hole isn't big enough to get the throttle cable into. I think I might be able to get the end in there but then the cable won't screw into that though since they are different size...
same thing happened on my cafe, i was just going to run one cable, instead i went back to the stock set up. no idea what to do, i though about drilling it out even, but never went through on it
I was thinking about drilling it out too, but I don't know if there is enough material there to do that or not... I wonder if there is a different cable to get then instead. I'll snoop around and if I don't find anything I might look a little further into drilling it out.
It's not the cable you need for the speedo you need the drive for the hub from a bike with a 21"wheel. the cable has nothing to do with it. they are all the same except for the length. I have 2 wheels an 18 and a 19 and i mixed up the drives and it threw my speedo off by about 10MPH Same cable.
Cheers,
Cheers,
I knew the cable had nothing to do with the ratio. I didn't know if it was the drive or the speedo thought that had to have the right ratio, sounds like its both though. I have the drive that came with the wheel on there so I should be ok there. Now I just need to know what ratio of speedo to get. Most seem to be 1:1 or 2:1 that I have seen so far.
Well I did enough looking and just decided to drill it and tap it. I've already drilled it and I'll probably get it tapped this weekend when I can go use my Dad's tap and die set. Its a 10mm 1.25 pitch tap and 11/32" drill bit that is needed if anyone is interested.
