Correct throttle cable routing? CB200 - Video example included
odin836
Active Member
Hope everyone had a good new year.
I'm looking for advice, and hopefully photos from someone kind enough to take the time. ???
Doing the last few things on my bike before I send it off to get sandblasted.
I am unsure about an issue that poses a safety risk, electric and throttle cable routing. When I turn my bars right the throttle cable is causing the bike to accelerate as can be seen in the video below.
Help please!!! Kinda stuck here as no clear direction in manual/service guides and as I got the bike in pieces no original as is photos to go off... :-\
Current situation in photos and video below...
<iframe width="420" height="315" src="http://www.youtube.com/embed/FfvIeoz17Zk?rel=0" frameborder="0" allowfullscreen></iframe>
Video example...
You need to brace your cable somewhere. I think a good spot might be to weld or bolt something to the frame where the cable splits into two.
Thanks for the info...
Has anyone got some photos from their build that I can use as a guide?
I assume its similar throttle and cable positioning for all CBs...
I'm not sure how he'd get it under the backbone with that carb setup. Then again, there are right angle bends available to fit those carbs for the cable to go through aren't there?
You need more slack in the cable. The cable needs to be moved higher up on the left side of the frame. Notice in picture #4 that the cable runs down to the other wires. It needs to run up higher like above the round rubber gas tank mount on the frame.
Here you go. It's not as sharp of a bend as you would think.
I'm thinking the problem is that when you turn the bars the cable surrounds are getting dragged with it. I think a short term fix would be to run the cable down the right side of the backbone and make sure it's secured. A long term fix would be a longer cable.
You don't get any snagging with that bend?
That's worth a shot first, absolutely.
JohnnyCB650 cheers for the pictures! It will certainly help.
I'll also take not to see if the cable surrounds are getting dragged...
Also, look at my first picture. Your clutch cable is wrong too. It should go over the head then under the bottom tripple-clamp before going behind the headlight ( the tach cable should go under the bottom clamp too).
Not trying to nitpick or anything so don't take it the wrong way. Just trying to help out. ;)
JohnnyCB650, any help/advice you can provide would be appreciated!
As I said, I have no "before" photos to go off, so have no idea of correct cable routing. The more photos you can provide the better esp when it comes to things like brake, clutch and accelerator related items, you might just save my skin...
Anything else you notice wrong?
I wonder, is the tacho cable supposed to go that way but around the other side of the steering tube first?
Ditto on JohnnyCB650...I just checked my CB550 and the throttle cable does not loop over the frame from left to right like it does in your photo...
odin836 I feel your pain. Half of my 650 was in boxes when I got it and I had nothing to go off of either. I'll say this about my cb200: It was definitely neglected in it's life but it appears to be unmolested (if that makes sense). So, I can't say that it's 100% correct but none of the controls bind or anything and the cables all have sufficient clearance that they don't get tugged on when turning lock to lock. Oh, and I can't help with the front brake; that was the one thing missing when I got it.
Here's a pic of the front:
