crane hi-6 cdi use on a dt250??? can it be done?
rd350 survivor
i was looking for a way to get a better spark out of one of my dt250s and came across the crane hi-6 cdi. it is supposed to work with 6 to 18 volts and with points. i know these cost a lot of $$$ new and take up some room, but since the stock air cleaner setup is gone i think i have the room and these can be had for about 50 to 75 on ebay:
Part Number: 6000-6440 BACK TO LIST Primary Voltage Output 450 volts Primary Energy Output 1200 millijoules/sequence Dimensions 8?L x 4-1/2?W x 2?H; 4-1/2 lbs. Operating Voltage 6 to 18v, reverse polarity protected, neg. ground only Current Draw 7.0 amps max. at 10,000 RPM RPM Operating Range 12,000 RPM (with rev limiter disabled). Peak Spark Gap Current 380 milliamps with LX91 coil, 510 milliamps with LX92 coil. RPM Limiter Accuracy ?30 RPM RPM Limiter Range 600 to 9,900 RPM in 100 RPM increments. Timing Accuracy ?0.5 degrees from 500 to 9,900 RPM Multiple Spark Duration 20 degrees crankshaft rotation below 3,000 RPM. Max 12 sparks per sequence with 1 millisecond interval between sparks. Application Multi-Spark CD, for race, street, 10 to 14.5:1 compression ratio, nitrousoxide, supercharged and turbo. More HP, torque, crisper throttle response! For 4, 6, 8 cylinder with distributor. Description HI-6 Capacitive Discharge Multi-Spark Ignition, black LX92 Professional Race Coil For use with Capacitive Discharge Racing Ignitions. Professional race coil for use with CD systems only. Highly recommended for maximum performance with Crane HI-6 systems. Gives up to 12 times greater output than OE. Replacement coil for Crane HI-7 system.Can also be used with mallory Hyfire, MSD 7 and MSD 8 systems. Caution: MSD 6 systems are not capable of driving the high current demanded by the LX92. Not compatible with Crane HI-6S system. LX91 Professional Race Coil COIL SPECIFICATIONS - Performanmce Ignition Coils PS20 PS40 PS60 PS91 PS92 Primary Resistance 1.4 ohms 1.4 ohms .40 ohms .43 ohms .20 ohms Secondary Resistance 5.2 Kohms 5.2 kohms 3.8 kohms 3.0 Kohms .82 kohms Primary Inductance 7.5 mH 7.5 mH 5.3 mH 5.5 mH 1.9 mH Secondary Inductance 26 H 26 H 15 H 16 H 6.8 H Leakage Inductance 1.3 mH 1.3 mH .50 mH .32 mH .14 mH Turns Ratio 60:1 60:1 54:1 54:1 60:1 COIL SPECIFICATIONS - LX Series LX91 LX92 LX93 Primary Resistance .42 ohms .23 ohms .11 ohms Secondary Resistance 3.5 Kohms .91 kohms .30 kohms Primary Inductance 5.6 mH 1.7 mH 1.4 mH Secondary Inductance 16.4 H 5.7 H 3.5 H Leakage Inductance .23 mH .14 mH .08 mH Turns Ratio 54:1 60:1 50:1
