Yes, Anything is possible... The time and money, are the frustrations. But I'm in no hurry.
I noticed several of the differences in the 200's crank gear/clutch area. I was hoping it would be a drop in. But I gathered enough information to know it would be a bit more complicated. I will be using the larger 200 oil pump on the 175. which was my initial reason for buying the bucket o' 200 parts.
I dont have a hydraulic press-- I found more information on hondatwins.net about DIY'ers building a jig to get it apart with their small 10ton press. I will probably take it to a machine shop and have them disassemble it to extract the 200's rods.
I would be interested to know what the lower 175 rod's big end diameter is. Could you let me know the size if you find one laying around?
If it works, ill stick to the idea of a 200 top end on the 175 crank. I dont want to spend too much money on re-sleeving a set of 175 jugs to get the 200's 56.5mm +1mm pistons to fit in the 175's hardware. It would be a nice idea seeing how metallurgy has come far since the 70's
-- another question, does the 175's case need clearance to accept the OD of the 200's sleeve? I couldn't find any definitive answers.
About the needle roller end caps you speak of, did the side covers/end caps reqire any machining to fit the bearing, or did you use a bushing to reduce the size to fit a smaller one? I had this idea also but haven't gotten into any measurements yet.
I would imaging you could use radial bearings pressed into the head, after machining off the points cover/thing to remove the reciever. *complicated to describe*
I'm not looking to built a track bike just something interesting.
Thanks everyone, Ill post some more pics the next time I hit the garage. The heat is murder!
