CRAP! Has anyone else broken this? WTF....
64bastagebomr
DCC - Supporting Whiskey Fueled Mayhem Since 2009.
DTT SUPPORTER
So, we finally got the bobber on the road last night and we went through two clutch cover mechanisms. It's almost like the bolt heads on the sprocket are rubbing. That doesn't make sense though...it's a stock setup with no modifications to that part of the bike. I'm thinking I could shave the heads of the bolts down a bit but I'm concerned there is another problem.
Any ideas?
On another note, Herm nor I could find replacements for the arm. Anywhere. The last one he literally made by hand, took him damn near 4 hours. Has anyone found a source for these?
Thanks.
J
Did you put an o-ring chain on it? could that be rubbing on it? Somewhere in the 450 forum on hondatwins there was a warning not to use o-ring chains because they are too big and will rub on something. Can't remember what.
Negative. It's an old school metal on metal chain.. I thought the same thing at first.
Looking at the Microfiche there are some variant part #'s. I need to check my VIN on the engine tonight. Herm seems to think it might be of earlier vintage which would require the clutch cable to sit in a different spot.
And we all know he's usual right so....
Looks like we'll be fabbing something up tonight. Given we can't find these things anywhere I could see this becoming a production item...
On a side note, the bobber pulls like no other 450 I've ever ridden. The big bore kit made a huge difference. Can't wait to really get her dialed in.
Will post more as we progress over this hump.
J
It looks like you installed washers between the sprocket bolts and sprocket retainer, therefore pushing the bolt heads outwards towards your clutch cover. In stock form, there are no washers.
there's a ball bearing that goes between the actuator rod and the clutch pushrod, if that's missing, then you might be adjusting the actuator too far out and rubbing the sprocket... it's about a 1/4" bearing, so if you're that off, it could be it
