SudburyBaller
I have a cx500, would there be any ill effects from piping my exhaust pipes into a stock can from a newer street bike. I don't have the stock muffler, only the header pipes. Planning on running under tail exhaust.
should work fine if the can is from a similar displacement machine. make sure you rejet otherwise you might be running lean. as hillsy said... might run better.hillsy said:It will probably run better.
