VonYinzer said:Those frame pieces + a cb360 motor = bad things...
I'm all for going off script but do some research on frame fabrication first. I know you say this is just for show but why not make it functional too?
trek97 said:this is getting weird in a familiar sort of way...
Heres a 360 thats a work of art and is functional.
xb33bsa said:the top tube is a glaring issue.you see it is not just the size of tube .was the wall thickness even the same as a 360 ? but also the length of run makes more difference than the gauge of tube and also how straight that tube is and above all how much it is allowed to deflect/flex regularly in its use because of the overall design
i wish you well and hope you realize that if all of these things are ignored and allowed to come into play you end up with a cascading effect much greater than any single one
it is astounding but i think you hit the mark on all of them unless you plan on at least doubling or tripleing the flex resistance with gusseting alone
im just sayin
Kamn said:how do you like the everlast welder??
thumbs upjag767 said:If you take a close look theres a football field of room between the backbone and the bottom motor mounts. A second backbone is going in, which will serve as the top motor mount. The gussets will go in after that. Also adding tubing around other joints around the frame to gain strength. Then gussets will be added as well. That is only the general design, I was anxious to get it in a roller. I will be going overkill with getting it good and rigid. As far as the metal in the backbone, exact same wall thickness as what was there.
xb33bsa said:splendid carry on 8) ts gonna be bitchen you may consider something to help stiffen that upper middle junction in the horizontal plane as well
xb33bsa said:the green tube could help but im not sure it is correct if you look at a ducati space frame for example the inner lattice tubes are not coming in at 90 degrees they all walk through more like 45's in pairs
and the gussets should always be on the outside near center line not the closest center reach
it could be eitherjag767 said:Hooray glad to get a blessing from someone in the know! Hmm Tube or plate?
o1marc said:Why the need to add all that strengthening on a piece of art. Why would you completely rebuild a motor on an art bike that won't be ridden. I smell a liar justifying his plans.
