Might be an odd request... how do you feel about making a harness for a CL360 using the switches/controls from a Harley? The bike I'm building is a hybrid of 3 different bikes (so far) with the CL360 being the powerplant/drivetrain. I have an HD front end on it and a set of controls here I'd like to use if possible. I could send you what I have so you could build it from there.
Finished up and ready to ship a new Honda 360 harness. This one comes with a Sparck Moto regulator/rectifier setup for use with a lithium ion battery, individual labeling of all the connections, a USB charger, and LED conversion.
Do you have pics of the HID and LED headlight stuff you offer?
Are you able to provide the plugs for FH mosfet rectifiers/regulators? (Furukawa QLW 250 3 Pin Female Connector Set For wire sizes 2mm - 3mm2 (12 - 14 AWG)
What does DIY leave you with in more detail?
Are you planning to offer solid state breakers instead of fuses?
I have two bikes in the works. A 74 Honda Cb450 that I need a simplified harness for. I have the original harness that doesn't look to bad. I also have a 1993 yamaha xt350 that I'm building a tracker out of. I have the components but the harness is all cut up. I need a simplified harness for this one. What would you charge for both?
