Custom Wire Wheels
Turtleface
Hello everyone! I've lurked for a while, admiring all the amazing bikes for the past two months, and have decided to get started on planning a cafe racer of my own. I've narrowed the donor bike down to a 1982 Suzuki GS 750E. I'm looking to convert it to more modern running gear, modern USD 750 GSXR gear in front, probably 2003 or so, and a 1100E swingarm and a more modern rear wheel size to accommodate modern radial rubber. I'd really like to do a nice aggressive, wider radial tire on the front and rear, without getting awkward looking (150, 160?), along with a front disk brakes, and a rear disk brake. Still undecided on a single or dual front setup. Anyone have a link to a place where I can get hubs, hoops, and spokes that are would work? Custom stuff is an option as well. Any suggestions on wheel/tire size?
this is going to be tricky... rear hub will be easiest to work with... not sure whats on the gs750 but i know for a dual disk front end with gsxr forks you can use a harley front hub with the rotors off a gsxr custom drilled and mounted to it... then bearings that fit the axle/bearing size of harley. you can lace that to rim of your choice.
buchanans is your best bet for one stop rims... if they are 36 hole rims and you want shouldered alloys, you can get wm3/wm4 from mikesxs
also think about if your going mono or dual rear shock... mono requires LOTS of planning and measurements... if your measurements are off you could get a rear shock that gets softer the more compressed it gets; BAD BAD BAD....
im sure others can chime in... try searching; loads of stuff here.
Welcome to DTT.
The only real issue, how much do you want to spend?
Buchanan's will run you about a grand or more after you find hubs to fit (if you want radial tyres your going to use 17"rims, if you want a 120 front tyre need 2.50"~3.00" rim, for rear 150~160 you need 4.50"~5.50"rim to work properly)
For rear hub, 2000 on MX will work and be plenty strong enough plus set up for disc brake.
Front hub, HD uses inch bearings so almost anything else will be easier to fit although you will probably have to make rotor spacers (I did one last year to fit Talon MX hub into GSXR forks)
You could have an axle made for HD hub but knowing what forks are like, I wouldn't
PJ
Sticking with dual shocks for the rear. Cost's not really important, just want to do it right. Ok, 120 front and 160 rear sounds good. So, Harley hubs on the front, MX hubs for the rear? Buchanans for 17" rims? Like I said before, I'm mostly planning right now, pricing things out. I'm shooting for most expensive scenario, for planning purposes.
most expensive scenario if you do all the work yourself...
i wouldnt be surprised to see around 3-4 grand depending on how much you get the stuff for...
hey pj... the last BOTM with the dual disk front had a HD hub mated to gsxr forks...
build thread....
http://dotheton.com/index.php?topic=10971.0
BOTM....
http://dotheton.com/index.php?topic=13802.0
I've got a coupe of Harley hubs I would like to offload, they are also real heavy
I got them to use as rears on 'normal weight' bikes ;D
I don't know how 'Suzuki' bearings fitted a HD hub, metric and inch are just not the same size ???????????????????????????????
(maybe its a late model Honda Davidson?-KYB forks)
here's what Squirely said.
Re: project "Vaseline" Squirley's cb 550 build
« Reply #31 on: Jan 16, 2010, 23:15:57 »
If you want to just do a fork swap and run a gsxr rim, the swap is as simple as ding a bearing swap by combining the two different bearings together (part numbers are on my build thread somewhere from all balls racing) you need a small spacer, about 3-4mm under the lower bearing race, and that's it.
Adding a spoked wheel is a little more challenging and I can tell you what I did here if your interested in doing the spoked rim thing too.
You can use the GS750 front hub and mate it to GSXR USD forks (91-95? - not SRAD). They run the same dia axle. I'm pretty sure the GS front hub has the holes for dual disc (they did in Australia). Not sure what discs / calipers you have to run, but I know there is a combination of GS/GSXR that are a bolt on fit ;)
Rear end - you can use the GS750 hub again with the 1100 swingarm. You'll be able to get a 4.5" rim in there easy (160 tyre), and I've seen people do 5.5" (180 tyre), but it's a bit cramped. You'll need an offset front sprocket and I think you need to narrow the front of the swingarm (pivot) to sqeeze it into the GS frame.
Have a look at GS Resources and Old Skool Suzuki - these conversions have been done a million times.
Much has been said about wide rims on wire spoked wheels costing an arm and a leg, and I think that's 'cause everybody gives up after looking at Buchanan's. I'm building wheels right now for my '82 CB750F, and I'm using the front hub from a '77 goldwing, the rear hub from a '77 KZ750B (same as KZ1000) and getting the stock spokes on the front wheel cut down and re-threaded at Buchanan's, but getting my rims elsewhere. I've found some great chromed steel Harley aftermarket rims on fleabay for around eighty bucks in a 4.50" x 18", they have 3.50 up to 5.50 in 18", but the 4.5 will fit the 160/60 tire, there's 4.25 to go with the 150 also, but I like the range of sport touring tires for Beemers in this size, I think Beemers will need tires for a long time to come, and they're a size that's fitted to some relatively modern bikes. I'm also looking at a shouldered alloy Borrani rim in 3.00" x 18" for the front, running about 150 bucks, or 95 euros from the site I'm looking at. That should allow me to get something in a low profile tire, I'd like to go up to a 3.50", but even a 2.50" allows a nice old school sized tire on it which was fitted to GL1200's, Harleys, and the like. Sporty though. The 3-3.5 should allow low profile radials, more plentiful, and available in 18" from a few suppliers, again for the sport touring crowd. And they say the new sport touring tires are getting sportier and sportier. I might need some new nipples for the rear rim, 'cause the Harleys use a wider nipple. I've even cut out the old comstar rear rim, I was thinking of doing the mod where the hubs have flanges on them for spoked rims, it's been done on the "dromedary" cx500 and other shaft drive bikes (though there are better ways, like putting the shaved down hub into an old drum brake hub and welding it up, seen that done too) but the comstar hub was heavy as shit. The KZ hub is way way lighter and it's half steel. so what gives? Anyway, what I found was a really good savings would be to take a look on the shipping of wheels you're thinking of buying, my wheels were cheap but cost a lot to ship, I could have had the hubs chopped out with bolt cutters and then replaced the spokes with new sets, and still saved money. Everybody is hung up on getting axle sizes the same, and when they do swingarm swaps they're hung up about pivot bolt diameters, but you do realize that they make bearings in a whole range of specifications, and "motorcycle wheel bearings" have all of the numbers stamped on them as to load rating, speed, longevity etc, and they're just regular bearings suited to the task. You could order decent wheel bearings in any industrial park, if you bring in some other bike bearings that would help to get the ball rolling. I just see so much effort going into sleeving shafts and stuff like that, it seems to me that it's a good way to weaken the whole installation, where you could just put fatter needle bearings into a swingarm pivot and such-not. Sheesh. Anyway, I don't see a spoked wheel as HAVING to cost you six hundred bucks per wheel. Buchanan's wants about $400 bucks for a really fat alloy wheel, and they're all drop center anyways. I've been told that it would require some custom spoke nipples, but you could use the rims off of cast sport-bike wheels if you have them machined down without weakening them. They're about three to five times as thick as any wire spoked rims in existance, my GL front rim is good evidence of that. You look at what a stock GL1000 front end was sitting on and it will make you much less confident in the bike, ha ha. But a cast wheel, cut out and machined smooth, well that makes a great rim to drill into pattern, yielding a heavier stronger rim. So, if it comes down to it, I'll use the comstar 18" x2.50" rear rim up front. Incidentally, if your spokes are in good shape (look for a low mileage donor bike, as spokes fail due to fatigue and hence have a limited life span) then Buchanan's will cut them down and re-thread them to a shorter length for a smaller hub for something like twenty bucks. And the two wheels I selected use heavy duty stainless spokes. Chromed spokes on some of the cheaper smaller bikes will be rusted out quite obviously. Buchanan's also has several spoke sets right off the catalogue for the KZ1000 rear rim, but they'll make stuff up for other hubs within reason. I was told the Goldwing rear rim won't fit up to my front hub because of the hole pattern, but they list an 18" and a 16" set for the KZ hub, so a 17" on should be well within reason. And the 17" rims have a well known range of tires. I would have gone with the original wheels as bought, but I found out the GL and KZ rims are actually smaller than the comstars on my 'F, though the tires specified are the same. I have a set of old tires off my 'F, as I was last riding it before burning out the engine, good tires, that were on the smaller end of the scale for those rims, and they'd have fit my new wheels perfectly. But once I got it in my head that I could have really GREAT tires as opposed to the same as before, for a little more trouble, well I got to work stripping everything down and polishing it. And that KZ hub has got to be harder even than the rear comstar hub I'd already polished up! It's got a texture like 60 grit sandpaper as stock, it's like it's rough sand cast or something. I'm still looking at an alternate brake, and the front rotor off the 'F fits the rear hub except for the off-set and the bolt holes, but I can easily drill four holes ha ha. "Melchiro" on my main forum, CB1100F.net, has drilled rotors to suit his chosen wheels, and they work great. So I'm not too too hung up on the bolt pattern. But, I've found that one early model of CBR900RR rotor fit the goldwing hub almost perfect, they just need the holes drilled larger for the old through-bolts. I might just use the stock rotors I've got, but they're heavy as shit. Seems like many CBR and Brembo (Ducati) rotors will fit too, but the table I had for specs has been changed, used to be an aftermarket rotor supplier that had an engine that specified rotor dimensions, but there are still rotor suppliers that list dimensions on fleabay auctions, especially the wave rotors from China. If the wave rotors are a certain size, so too must be the OEM ones, sooo..... Yeah. So you see, if you're willing to put enough time and effort into it, about as much as though you put in an hour of labour per dollar saved, you don't have to pay an arm and a leg to build wire spoked wheels. I've seen some mistakes though. A guy on the F forum got awesome rims and spokes from Buchanan's, but used a sohc CB750K hub, with single rotor, and bought a second hub and milled it down then bolted it to the first, in order to have twin front rotors, and then had to mess around with offsets for the calipers and everything. But if he'd taken the time to select the GL1000 front hub in the first place, it already would have come with the twin rotors. See? And that guy was BRILLIANT, his build thread is still famous on our forum. There are lots of ways around things though. If you can accept the lower selection of sporty tires found on 18" wheels, then there are many many cheap wide rims available due to the chopper crowd making conversions for the sohc CB's since the '60's. I wouldn't put 'em on my 'F, but maybe on the KZ440 I wanna fix up next for my daughter, I could see 16" wheels front and rear, with one of those cheaper 3.00" rims up front and maybe something much fatter in the rear maybe a 5.5. and then go with a sporty tire made for 80's era VF-R type bikes, possibly with a radial tire made for cruisers, if compatible -possibly from the same line or similar at least - that would be a rim set that would be cheap to find due to the plethora of choppers out there. Seventeen inch seems to be something more and more common on choppers now, and the supplier of the Harley aftermarket rims I mentioned is looking into seventeen inch rims for me right now. I'm sure there will be more of them as time goes on. Heck, if you wanted to stay on the conservative side of things you could buy a pair of stock wheels of the type I've got, and mate them to the Borrani alloy rims in a 3.00" rear probably netting a 140/80 tire in rear, and a 2.50" up front netting a 120/90 tire, they'd be more of an old school tire and all, but they'd be at the upper upper range of sizes fot that type, and the Borrani rims would run you about 80-90 euros each, or less than three hundred for the pair. Flanged rims, they look really cool. If you can stand the enormous 19" rim on the Goldwing in the first place, maybe the 1.85" rmi on it is good enough, I dunno. But the original poster here mentions tires of the type I'm looking at myself, and I say go for it! Ha ha. Now, another consideration is with the swingarm and chainline. The CB-F already has a wide swingarm and wide offset chainline, people put Gixxer wheels on them all of the time. But a mistake I see people making often, is messing around with offset sprockets. With some pretty simple machining, (heck one dude did it on a drill press) you can machine down the sprocket carrier / cush drive to hold the stock type driven sprocket in line with the stock front drive sprocket. That's on the 'F mind you, which doesn't have the roller-bearing crank of the GS or the KZ, so I'd hesitate to advocate for this as the reason to pick the F, ha ha. The swingarm swaps done on the 'F forum are like many other swingarm swaps, but they have a heavy emphasis on using modern sportbike swingers. One thing to say is that many of them are alloy now, and they're not all massive and heavy. I'm sure that there's something made in the 90's that doesn't look monstrous on a classic bike's frame. I'm doing a lot more on my build with rear-sets and clip-ons of my own construction, and bodywork too, it's an ambitious build held hostage by finances and my health issues, but coming along slowly but surely. In any case, the wheel stuff has been pretty straight forward so far and the bike should be sitting on rubber in a short time. Just don't hold your breath.
-Sigh.
Go Back in there and fix punctuation. (Paragraph breaks, etc) ;)
as you've pointed out, it's possible to get wheels done cheaper, if you know where to look and what to look for
Find a trashed Suzuki DRZ400SM and get the wheels out of it (or similar Supermoto bike)
The cranks and cylinders wear out around 4~6,000 miles because they wheelie so well ;D
HEY, Dammit. That's not even a paragraph, that's only one sentence! You guys have no idea how long some of my posts can get. Maybe I'll post around here more, tough to say. But if you were over on CB1100F.net the past several years, you'd be pretty damned appreciative that I didn't tell you about my sexual exploits or a job I used to have that I hated or ... I dunno, bitch about what a lunatic my ex "wife" was, in ways that make it VERY clear that there was indeed a certifiable lunatic in that relationship. This post is all about bikes, dammit. I don't think I mentioned rare esoteric aquarium fish or house-plants nor did I tell you how to set up a cheap green-house with integrated "aquaponics" for a protien source for post appocalyptic survivalism, and from there I would usually go off on a tangent about a gov't lab aquatics job I once held, or write a screenplay explaining how the meth epidemic within a group of KZ1000 enthusiasts flared up into a nuclear war, "Mad-Max 1.5 Mad World Mad World It's A Very Very Mad World" I didn't talk about '80s music at that point either, and then because it's tears for fears and I'd already mentioned a movie with serious homoerotic undertones and overt displays of leather-daddy/slaveboy love, I probably would have broken off into a slightly homophobic exploration of gender issues and the motorcycle in cinema, let alone the design sensibilities of motorcycle sub-cultures and their obvious gay implications and blah blah blah, which obviously on a Cafe forum would be really really offensive, despite the fact that I always defend the Cafe scene for hanging it all out there in the open rather than attempting to repress it to the point that your sub-frame gets an erection that sticks up between your things and the bike itself wears numerous Euro-trash Pickelhelm spikes as though it were a damned "Ampallang" or "Prince Albert" ... and probably all the rest of them thrown in for good measure, ball sack tucking cock ring and all, around that now erect sub-frame and seat ... and all of that is really offensive to any street-fighter buffs hanging out in the wings, ostensibly 10% probably more, or maybe the stats just mean that EVERY dude is 10% street-fighter buff, and then I'd have to talk about the Christo-Fascist Reagannite Right-Wing and their 1% interpretation, which is such a liberal definition of what it means to NOT be a street-fighter fan just somebody who "Dabbles" with them, when acting as a youth pastor or some such.... It's all such a fascinating thing. And lemme tell ya, on the CB1100F 'F-orum, they just can't help but egg me on with their whole "Cafe Gay" comments all of the time, so it just goes around in circles.
I thought that I could find acceptance here like the Small-Town Boy from the Bronski Beat song, but no, I am just unloved. Unloveable. 'When you say it's gonna happen NOW, well when exactly do you mean? 'Cause I've already waited too long. And all my hope is gone." Sorry. Just listening to a bit of '80s music there and it seeped into my stream of consciousness.
But seriously, if I'm givin' you ALL killer thriller and no filler chiller diddler whittler meddler bed-wetter, and you think THAT looks like my SPAM SPAM SPAM SPAM SPAM SPAM SPAM
Hell, what you're getting there is the "Lobster Thermidore Aux Crevettes with a mornay sauce and garnished with a truffle pate' brandy and an egg on top ,,, and SPAM."
I hardly think it's worth buggering with.
In any case, everybody is all rapping about Supermoto wheels. Well, that's great and all, but what you want to look at first and fore-most on these radial tyre swaps is the load bearing capacity of the tires in question. You really NEED to stick to the OEM ratings because a tire that is rated lower for weight you're basically trading the weight for the speed, so you're paying for a ZR tire and getting less than an H, say, for the given weight of your bike and rider, luggage, passenger if two up, etc. The supermotos are pretty much all seventeen inch, they don't even have the look you'd be looking for on a bike like this so they defeat the whole purpose of the swap, and you're competing with a whole other class of riders/builders for a much desired part. Why bother, if you can build a proper wheel that suits ALL of the variables of what your design calls for, and that's once they're really analyzed, not just "does it have spokes?" that's a really short-sighted explaination. I have to say, maybe some people who're working with a smaller twin or something, THEY can get away with that type of logic, but NOT on a larger early Superbike with it's enormous mass, relatively speaking. I can't tell you how many times people have given this pat answer and I'm telling you, it's false economy 'cause you'll spend more and they'll look like shit. I dunno, maybe to a lot of people the details don't matter. But the Borrani rims I mention are a true classic rim. You can't find anything like them in the typical alloy rims people are using now. Take a look at the difference between the GT1000 Ducati wheels and the standard alloy Sportclassic rims. They're radically different, the GT are chromed steel. This is a slight weight penalty that a lot of Duc owners are swapping out 'cause of, or at least you'll get 'em cheaper than a set off a Paul Smart Replica, that's for sure. Actually these Duc wheels are more affordable and more available than the others, but again you're sacrificing the shape of the hubs which is a very important detail of a classic bike to a lot of folks. I mean hell, if you wanna talk about who's response seems more "computer generated", then what has circulated around wire wheel swap threads more than say, well myself ha ha, more than saying "Supermoto Wheels" ... paradoxically juxtaposed next to "Cheap, second-hand" I'd really like to figure out where that is. Heck, I've seen a few pairs of these DR supermoto wheels up close around town, and they pull off the effect nicely on a little dirt bike, so truly they would be great on a similar sized bike in the form of a classic twin of smaller displacement perhaps ... heck, I'm KIND OF looking at doing that on my little KZ440 over here. The LTD is actually winning me over, seeing some of the builds that have been pulled off with 'em lately. Might even keep the tank. Not likely, but if I cheap out, and the kid likes it then fine bike me. Still, I think my KZ 400 drum brake version of this build, using some cheap chromed steel 16" rims, or MAYBE 17" rims, would be a much more interesting build, visually speaking, than giving the bike the legs of a modern dirt bike. Heck, I'll try and get as big of a drum up front as I can get away with, but I was also thinking of sticking a disc on the flat dome side of the drum, ha ha. Shouldn't be too too hard, actually. With a solid enough disc, sized appropriately, it should look just like a normal disc brake from one side, and a drum from the other. Ha ha. Just a thought. The one could be a panic brake. Though, I prefer the idea of using a regenerative electric brake inside that drum, on an electric bike, with the disc for back-up brakeing. Dunno if I'll go electric on this one just yet, we'll see what the cost of the engine rebuild looks like when I get around to it. I used to just pop in a new junk-yard engine when they blew on me, cheap short term fix. But I've still got a spare kicking around, and they probably just needed new carb diaphragms anyway. Oh, I patched 'em back in the day, but I think my synch problems were just that, not ostensibly bent rods and what-not. I think that "bent rod" was a poorly synched crank throw, who's to say. I forget if that was a built up crank or not. It was a kawi after all, so probably. Would wanna balance that crank and then weld it and THEN lighten it, if that's the case. So, MAYBE a cheap-ish fix on these old twins, maybe not. Still, like most of my posts "NOT GERMANE" ha ha.
But yeah, I really feel strongly about using appropriate hubs on a wheel swap for a classic build. I'm using a Kawi hub on my Honda, but at least they're from the same year/era, and it's lighter which was one consideration, well that and the fact that the SOHC CB750F SS wheel hub is a very much in demand item when everybody and his dog is tricking out a SOHC CB, and usually as a Cafe now that I mention it. Anyway, yeah the CB SS rear hub was off the menu for several reasons, but I didn't wanna just ditch the enormous over-built (?) cush drive, being that I've got a CB here with it's reputed output shaft bearing weakness.... As for the 440 twin, who the hell doesn't love a good drum brake? And I've set up my own smaller Honda drum brakes, I know what to do, de-glazing etc, I know how you can get the most out of 'em. So I don't see it as too much of a trade-off. Quite the opposite. It's just too bad one can't get the old double sided hubs anymore, 'cause too many classic British bike racers are building with the GT750 and the like hubs, due to the cost of genuine article reproductions of Oldani etc. It would sure be cool to net a GT hub, or a Suzuki Titan hub, even the CB160 hubs are all out there used on racers, at least they're on Hondas ha ha. But the 160's are on the 125's, and the 160's are using everything else that's slightly bigger. Ha ha. Good for THEM I guess, but not great for somebody who wants a small displacement street bike with a classic big drum up front. CB350 seems common enough still. So too, KZ400. I've found whole KZ400 wheels for a buck to ten bucks a pop, just the shipping is prohibitive. Been thinking about asking for the spokes cut out. They're shitty chromed spokes anyway. Not like the stainless ones on the GL and the bigger KZ, like I bought. Still gonna replace 'em, but I'll see to it that these ones get used at least. It's becoming more and more important to me, the more I look at MX hubs, and Harley wheels, and think about sticking them on even my lowly little 440. Was in the middle of ventillating the hubs for my old C70 Passport, when it occurred to me that I might want something like a CB350 hub in there, IF it will fit. The new aftermarket 140cc motors on those little scooter have got to strain the brakes a lot more than the old stockers.
Heck, I've been hung up about replacing my OEM GL1000 rotors, I got pissed off breaking drill bits 'cause I was drilling 'em without a drill press. But damn, you know the more and more I look at the CBR rotors everybody and his dog is putting on their classic hubs these days, I am thinking "That's some CLASSIC STEEL, baby." I've waxed poetical about older Jap bikes being made from the melted down carcasses of WWII Kamikaze planes and crap like that, as opposed to the recycled pop bottles everything is made from now, and how that translates to the difference between a bike that's got your blood sweat and tears in it, etc etc etc. But now I'm also looking at these rotors here and I'm thinking, hell it may not be Xena the Warrior Princess' "Chakram", but it's still some classic steel, and maybe it's made from melted down bayonettes or low ranking officer's swords or some such, cannon barrels from the imminent replacement for the Yamato, etc etc etc. In any case, I am now leaning toward keeping these rotors just going with a slightly larger hole in the drilled pattern. Or, at the very very least, I've got to look for a much more classic looking floating rotor from the '90s, 'cause some of them look kinda like an early floating EBC version of the CB/GL rotors. Stick these guys on an alloy carrier the same shape and size, maybe some small "buttons" instead of the heavy rivets, and that's the rotor you want. Not the spidery thin cheap looking bling off the modern crotch rockets. Fact is, if you have been reading the mainstream crotch rocket bike 'zines over their development history, the whole rotor thing itself has been laughed at over and over again because their design has more to do with trends ((((and visual preferences predicated upon BS arguments about how many buttons less or more etc that were a solution to a problem that never existed)))) more about being trendy than say, a Performance Machine wheel for Harley has been.
Definitely gotta ventillate 'em, but not with the cheapo drill holes in it method. That's starting to look crappier and crappier the more I look around too. Anyway, nice thing about the rear KZ440 drum is I can keep the whole brake shoe and cush drive if I use the early 400 drum. Maybe even throw the belt drive on the thing, who knows? Ha ha. That bike was scrap to me for years and years, I just didn't have the heart to throw it away. Now I'm seeing great electric conversions and cafe/street-tracker builds based on 'em, so I am rethinking it's value quite a bit! The damned wagon wheels are still going to the scrapper, no question about THAT. Ha ha. Gotta be a good price on all of that alloy, worth more than they are as bike parts by a LONG shot. Do I feel like an asshole? Well, maybe. IF I had a yen for cruisers. And some I really really like, just ... NOT his one. Ha ha. Why? 'Cause it was my first highway capable bike, that's why, and I was still tired of it after one day on the open road. Maybe my little girl will get better performance, that would be like taking me and my ex's luggage off that bike, and leaving the hundred pound blondie. That makes a heck of a difference. Probably won't even bother with passenger pegs on that one, ha ha, unless she demands it, which I know she will. She's already been asking for a custom set built illegally onto the little Jazz I bought her for her 14th. Of course, we talk about bigger bikes, and she's picked out a bone stock fully faired CB900F2 with the Hondaline luggage from my entire bike magazine collection. That's my GRRL! Ha ha.
I like small bikes, a lot. Used to ride the C70 as a fun alternate to the DOHC 750, but a middle-weight can often have the worst of both, rather than the best. Still, with some lighter wheels, a quicker front end from a dropped stance a slightly jacked up rear, maybe just an overall lightening by stripping it right down chop style, just with a cafe stance, that would be a great little lightweight performer, as opposed to a middleweight. And if a nice little CR450 engine fits in there, with some polishing on the cases, maybe a spare barrel and head bought so I can braze a bunch of cooling fins all over the water jacket in the style of an old Two stroke, who knows? It might just be AWESOME. Ha ha. And the thought of a rebuild single, as opposed to an old twin with dwindling parts supply, it's appealing. So many options when you're not attached to that engine. I guess I'm probably offending a lot of KZ owners. Ha ha. But hey, I think the same thoughts about a spare DOHC 'F chassis I have kicking around, so it's not just the KZ. I honestly think of it as a bike with a hell of a lot of potential, that's just dragging around a ball and chain on each wheel, so what the hell. Take that spare head, port the hell out of it, or at least port match it. Put some non CV carbs on there from an older 400, maybe with the throats bored out ever so slightly..... Could be a monster on par with any other 500cc twin in it's class, rather than just a good reliable bike that didn't hold up to the shit and abuse I dealt it in my mid-twenties. Loads of other stuff on my mind, if you only knew how and why I toasted two engines in a row one summer.... One of them on it's shake-down run. Ugh. Without question though, IF I have to get a replacement engine, if it's gotta be rebuilt I'll go for a 400 and up from there, 'cause of the kick start. But if it's a 440, then I'd go for the final year, the ... 81 or '81. My '80 had that damned through-engine push rod clutch actuator. What an unpolishable turd. And right in front of the sprocket no less, where it will get all sorts of crap on it's swash-plate. Just a total POS as I recall. Of course, that judgement is clouded by viewing it through the lens of a 25yr old brain, and I shouldn't say that broadly about all guys that age. 'Cause MY brain was stuck between the ears that were stuffed between the cheeks of the high-school sweet-heart, and stayed that way until I reached the ripe old age of thirty, an experience that rendered a 17 year old bronze god of a fitness nazi who woke up and stretched and then dropped immediately and did at least 1500 push-ups every morning, 17inch biceps, a stomach like a bag of hamburger buns, legs like tree-trunks, track and field rugby yoga tai chi half-pipe and downhill sk8 addict, just a total frickin' machine, into a cripple with the lower spine of an 80 year old man. As much as anything, because of all of the pelvic thrusting, as much as it had to do with the way he was trained at home such that she gave him the nick-name "slave boy" then later subverted that "house-broken-ness" to her own get-rich-quick purposes. DO NOT, I repeat DO NOT let your girlfriend or boyfriend or eunache whatever you're pounding on, don't let them watch those damned Home and Garden Television "Flip This House" programs, whatever else you do, if you have to drag them into the bedroom and eat their ass for an hour in order to distract them, just flip off the tube as you pass by, it will pay dividends in the long run. And watch out they don't hang out with other DINK yuppies who have gone the real estate route, if you have to make sure you hang around with people who've had kids instead, and make a show of your da-da potential. That part of things is actually rewarding. Just don't, especially not in your first "marriage", your "breaking in" marriage, don't get sucked in to that crap, just nip it in the bud while it's still in the quasi-Ikea appartment decorating phase and just get her out of the house more even if it means sending her out with her girlfriends to watch strippers.... Actually in my ex's case, it was usually female strippers and it usually ended with her playing stink finger with her best friend and then feeling awkward about it, then needing new female friends soon after, to the point that even though a guy would be sick to death of being ridden like a see-saw, he'd be there just to make sure she didn't switch teams permanently. You've gotta be there to go "whoa lady, what do you think you're doing with that Sony Rabbit vibrator? That's the hole of the love of my life! Let ME stuff that hole." Because those things are apparently vastly superior to the real thing. What are you gonna do, go have some kind of peircing done that implants a vibrating egg into your dick? You might never get out of the bath-tub again! No, hell you've got to keep "on top of things" ... but somehow and we didn't even have TV at first she was still watching that garbage, and my whole damned life not only got ripped apart to move to a town I grew up in and hated, but I totally permanently screwed my health up over this crap. The damned "Flip This House" shows were actually HER contribution to the whole renovation scheme. That and standing around holding a hammer and looking good. Ugh.
Anyway, all of you young dudes? You've been warned. That's my way of appologizing for making a generalization that you all were as stupid as I was at that age. Not friggin' possible, but all the same, I'm trying to appologize. I'm giving you my "pearls" here, don't swine about it.
But yeah, the KZ440, and for that matter any other twin in it's weight and power class with massively heavy wheels, well thats what it boils down to I think, the massive wheels and those stupid stupid cruiser tires with the massive side-walls. I'm thinking, the front tire from some kind of early VFR, if you can still find 'em, and in back, whatever equivalent rear radial in 16" or maybe even 17" that will lace up to a 5" by 16" or 4.5" x 17" rim. That would be a 150/70ZR17 in the latter case. Recommended by many as a good tire for my big four, but waaaay way under the load capacity of the original bias ply. NOT a good idea. with the side-wall flex of a radial, that tire would be really really bending under that extra weight, and then you've got a lot of heat going into the picture. Probably good for traction, but it's gonna raise your risk of a blow-out at speed with slightly lowered pressure just as an oversight, by a huge huge factor. The 160/60zr18 of the same width rim in the bigger hoop, well that's gotta have a good two hundred pounds extra capacity. Basically the difference between running with a passenger, and without. SO, maybe on a bike that will NEVER be used for two-up, that nobody will stick passenger pegs back on it by welding up a couple of bungs for a crotch rocket style alloy peg hanger coming down from the top rail, or that they're never gonna switch back to an OEM peg bracket/plate that hasn't been butchered by a sawzall..... Too much worry for me, personally. Ought to be done right once and left at that. And that bigger "over-rated" tire would give you the ability to lower the pressure if you wanted, to get more traction for a slower twistier track or canyon session. So not ONLY insurance, it's giving you options as well. And that 18"-er is actually made in waay more versions, than the little 150, so the old axiom, often repeated SPAM-LIKE on threads about wheel-swaps, that "17" wheels will give you more tire options" just doesn't apply in this case. Fact is, the bikes that use this size of tire are often Beemer long haulers. So as long as there are plenty of those beemer four valve twins rolling around, on their OEM wheels because their wheel swaps are a LOT more complicated and not just 'cause they're shafties, they're also Beemers on top of that, so long as the legendarily long lasing BMW twins stay on the road, the ones built in the late 90's mind you, and usually in the hands of wealthier riders too, so long as that situation exists, the 160/60zr18 sport-touring radial will be made. Probably long after there's no gasoline to run the damned things. I don't think I can say that about those 150's, that might just run into the type of problems people have with sourcing 16" rear bias ply and early radial sized tires for their Bimota/Harris etc wonder-bikes. I know, the VFR tire I'm talking about for the 440 is right square in that category. But there are still VFR's out there, they'll last as long as that KZ, unless it does go electric, ha ha. As for the rear tire, that's something that may need messing around with. At the very least, a rear cruiser tire of the new variety put on the Harley Dressers with the classic 16 by 16 wheels.... Probably gonna be plenty of them on the road too, for better or for worse. They'll guzzle the dwindling fuel, so they won't be touring as much in say, thirty or forty years. (((But I'd bet those Beemers will, ha ha. I'd bet their lay-out would lend itself to an electric or hybrid engine swap too, especially given the strong chassis built for the big lump of a motor....) in any case, people will still hang onto those dinosaur status symbols, so the Harley tires will be available. AND, it seems like the 16" radial is coming back in style. As are the 15's, and not just on choppers. Look at the desmosedicci. A big fat fifteen out back. I'd bet that front tire would make a great rear on the 440, ha ha. A front tire out back, that will make the steering even more skittish than it will be with an altered stance. But it could use it, it's so rock solid now, especially when those 16 x 130/90 tires flatten out. Ugh. You'd really want a tire with a tall profile on the thing, if you were gonna do a lot of straight line riding on it, just for the wear of it. There are probably other radials available, I should just go back to all of my notes and bookmarks from my DOHC wheel swap, as the tires were a major consideration for choosing the rims. False economy indeed, to choose cheap rims that would mess with me every time I needed a new tire. That adds up. Heck, I'm pissed that I can't get that 4.5" rear rim, and I'm gonna have to stuff the tire onto a 4.25", just because Buchanan's doesn't do the recommended rim size. Now, IF I had gone with a steel Harley rim (OR even an alloy one), then that wouldn't be an issue. I'd better not get less than the stated mileage out of my tires, while somebody else gets longer lasting rubber out of the same tires on the same bike, because they went with the fatter rim..... Not bloody likely, it would have to be the same rim all in all, if I wind up using tubes instead of managing to seal the rims with rubber strips and fibreglas over top of that ... thinkin' here, lithium grease on the inside of the nipples, clear silicone aquarium caulk on their outsides, then a bit more Lithium grease around the bases to discourage any galvanic welding, and then a rim strip covering over all of that, maybe even one made from a good beefy 16" inner tube with a heavy duty valve on it with replaceable core in it, possibly reinforced somehow with a protective sleeve perhaps ... but then, over the too tight rim strip, a layer or two of carbon fibre cloth, in a resin that's compatible with the rubber.... Or at least, change out the air in the tires frequently, using Nitrogen .... It would probably work. There are now several cruiser wheel builders offering sealed tubeless compatable rims for one or two hundred bucks over stock. For the harley aftermarket scene, that means they're sealed with Elmer's white glue. So, it's probably do-able with the type of thing I'm talking about. Maybe with a proper acid etch on all of those rim holes and on the nipple heads, and then a light light coating of a clear aquarium silicone, or at least a bathroom one with fungus protector ... provided it won't hurt the rubber ... Tires will get replaced soon enough anyway, probably not that much of a problem unless you were running tires too long set up on a sealed rim that handn't fully cured..... But yeah, set it up so that we're talking about rubbery faces on all of the mating parts, but good enough that they'll still seat properly, And THEN the rim strip to seal it, or maybe just the silicone I was talking about, for a light light coating that you can put in selective areas so that the epoxy in the carbon fibre will still have the spaces in between the nipples to grab onto.... And they'd be sanded and acid etched in there too, just basically a lttle dab of sealant over each nipple head, of course, once the wheel has been torqued and re-torqued and final balanced. The inside of the sealant will have to have a coating of some type of rubberized material, so that you could still use "Dynabeads" to balance the wheel dynamically.... And yeah, just a very very strong light carbon wrap around a very narrow rubber strip, or a rubber strip with holes drilled in it for contact between the nipple heads, just simple simple, the wrap being there to keep the tight rubber rim strip from coming off the center of the rim during high speed runs, to keep the mass from spinning under braking and accelleration.... I'm beginning to think this won't be too too hard to accomplish. There are aftermarket Ducati rims that just use a special o-ring on every spoke nipple. No wrap what-so-ever. Probably a high tech material. What's the stuff they're replacing all of the engine seals with nowadays? Yeah. "That stuff". Ha ha, 'cause it's long wearing, won't degrade. Still, I think my "Ghetto tube-less" version will hold up for the life of one tire at the very least. And if it needs to be re-done, it could be re-worked without dissassembling the wheel, as with a nipple head o-ring or a sealant on the nipples, etc. I'd use that stuff, but only as a back-up, the silicone to me would be only there to keep the stainless from sitting in a little drop of water and road salt. Far better, silicone or some lithium grease in there. I dunno about painting the whole wheel after assembly. I also wonder what a powder coat and the heat treatment inherent in that would do to the wheel's balance and spoke temper.... But still, people do it. I'd be thinking maybe a clear-coat over the wheel after this is all done, over top of the other clear-coat I mean, with the silicone layer in there.... Maybe just a good coat of that silicone spray they seal camping tents with. Just spray it on the nipples like it's Armour All. Ha ha. Dab it on with a brush every now and again. But still, just to keep out the weather and the elements. The real tube-less seal would be from that too tight 15" or 16" inner tube strip. Well, if you're not using a replacement valve, which could be placed on a bare spot in the wheel....
Think about what keeps your rubber valve stems in there. The comstars just have an old automotive type rubber bung, I think it's a different size and all, but it's still a fancy cork, when you get down to the brass tacks. So, other than the multiplied failure points inherent, each nipple treated the same way as that valve stem, would seal air just as well. And then, I suppose I would wanna seal up the whole wheel with a drying latex goop, a little while before using the Dynabeads. If the o-ring on each nipple type of thing is good enough for track spec Ducati Sportclassics, I'm sure it works just fine. but you'd be looking at something like ... a different nipple I guess. I dunno why Buchanan's doesn't start making the damned things for ALL of their spoke sets.... Sheesh. But yeah, you'd need the given bearing surface, and then a standard -ish gap for the seal. So, probably a lot more involved in the wheel design, hence their expense. Tough to say, it could just be that they're exclusive, and expect a lot of product recall, warantee work, liability etc. But at the very least, building a similar spoke nipple for doing an entire multi-system treatment on your rims, like I'm talking about here, those fancy nipples would be another layer of insurance.
And hey, how about instead of the tubes, the "Tire Balls"? For MX. Have you heard of them? A whole little set of rubber balls. One of them blows out, and you don't even know it. I guess you can even link them up to a pressure balance line, so they stay equal, or at least equalize them at set-up, not too sure whether that part stays in there or not. Probably not. It's fascinating though. These little buggers would have all those extra walls in between them, each shaped like a "key stone" I guess. But all the same, they'd be thinner walled, and probably lighter! I'm not yet sure they're being used for street.
I think I already mentioned the "Tu-Bliss" system for MX as well? Well, that thing also acts as a rim-lock. I guess the balls do a bit too. But the Tu-bliss allows MX people to ride with ZERO pressure, for extra traction. I'd bet that the bicycle nazis will love that shit. Oh, and I can call them nazis because I've lived inside one of those health nut enviro obsessive freaks before. Though I never spent five grand on a titanium framed bike, so I was never a bicycle nazi. Just your basic foot-soldier. Anyway, I think they would love the Tu-bliss for mountain bike wheels. To me though, while I don't worry as much about pinch flats as some people do, I kinda like the idea of a rim that keeps that tire just locked six ways 'til Sunday. I've got "rim locks" from my old wheels, I sure don't like 'em on my old KZ wheel. The drilled holes have gotta weaken the rim. So too with "grub screws". But the Tu-Bliss thing, IF you could use it on a bigger street type rim, then I'm all ove that shit. It's just that the sleeve for the smaller width rims is some type of braid reinforced hose, and something wide enough for the fat rims I'm thinking of, well the tires are a lower profile, so a round hose would be too tall over all. It would sure be cool though, if they offered a version with multiple wraps, or perhaps a spiral wind with a stitched up end, for the fatter rims, so you could have that half inch or inch of that sealant sleeve, locking up your tire's lip right down to the rim, and it would cross side to side without coming out too high in the profile. Spiral might be difficult. And concentric hoops would need to be cross linked. I think I'd be willing to put in some type of special valve holes for that, where you would have three very tiny bicycle type valves, rather than one big fat stem. But who's to say, maybe this type of thing would be over-kill on a street rim. Maybe that tire lip is just fine without the rim lock, maybe the whole system is weight prohibitive, whereas the MX ss=ytem is competing with "Python tubes" and "Mousse Tubes" with some type of open-cell foam crap inside of them, all of them full of "slime" which sound great and all, but had gotta be heavy. I keep reading about cross-over riders, not just dual-sport owners here, but one guy was talking about his KTM RC8 here, about using the slime and the heavy duty tubes, just for insurance against a blow out. Gotta wonder, with the extra heat in there, is he actually making it worse??? I can't see a double layer of carbon cloth coming apart inside the wheel. Maybe with a hard impact. But the Tu-Bliss type of thing, I can kinda see that moving around. Tough to say. But of all of these different methods, I think the one I've cooked up in my imagination is probably the lightest, most durable, and the cheapest way to do it overall. Twenty to forty bucks per tube, that's what I've seen here in Western Canada. Maybe I'm buying the wrong ones. Ha ha. Still, I think that would buy a LOT of carbon fibre and bondo resin. They have non-toxic resins now too. That would be the least likely to form some type of slime or crumbling cracking crust inside your tires, so I'd prefer that to Bondo, just in this one instance.
As for the valve, maybe even one of those thread-in alloy valves, just so one could put in a good fat gasket that would be more gentle on the carbon wrap. Not in a crappy looking pink anodized billet either, just a simple classic line.
Speaking of lines, I was looking at the AN fittings the other day, on their website, and it turns out I won't "have to" use those awful red and blue lines with the stainless wrapped lines. They've got a nickel coated line of fittings, and a black cloth wrapped line for them. So my oil cooler project for the deep sump Motoren-Israel BMW type sandwich layer sump plate I'm trying to finish up here. I can put some lines on the thing that will look just like the OEM oil lines on the SOHC bikes. That will go very very well with the whole "DOHC Sand-Cast" theme I am going for. A little more expensive, heck I'll probably only be able to afford cheap brass plumbing and heating "gubbins" at first, but sticking with threaded fittings with teflon wrap, I can swap them out later. Though, I would most prefer a weld-on bung type of AN fitting. We'll see, after all it's just a spare 750 DOHC sump, total throw away part when you're doing the oil cooler mod. But maybe not after I've shown the world my deep sump mod, hey? We'll see. Anyway yeah, a premium price on those nickel coated AN fittings, but just two of them at the bottom, maybe black anodized up top where they're behind the cooler anyway, heck I would splurge the extra ten bucks for the look. The black line just completes it. I don't like the stainless line look at all, and the red and blue fittings really put me off even more. but now that these fittings are out there. Mmmm. There's the oil tank mod for the dry sump versions of the DOHC too, the whole things' got me thinking about adapting the SOHC oil tank lines for that purpose as well, being that the modded oil pump cover would be a one-off part custom built anyway, you'd be looking for good cheap "horse head" fittings, so why not. Maybe sent that off to the AN people, get them to clamp up the new hoses to 'em. There are other people rebuilding SOHC oil lines anyways. But yeah, the dry-sump type lines would look sooo soo much more "Sand-cast -esque" with the black lines and alloy horse head elbows, and then the same treatment on the oil cooler lines. Oh man, that would take the whole look of the cheap aftermarket hot-rod store look of the typical AN fitting project, and give it a very vintage OEM look and feel to the whole thing. And it's the same parts out of the same catalogs, just a new treatment, and not just a silver anodize, but a full nickel coating. Damn, that is classy. Maybe an extra three bucks per fitting, four fittings on the oil cooler, the black hose is a little cheaper I think, same ratings ... and then whatever it would cost over and above doing up a mod for the dry sump type pump for the RSC RCB1000 treatment on the DOHC motor. I also think that the sump mod method here is gonna prove to be a good way to build up the dry sumps everybody is dreaming about but the supply of which was dwindled up.... Shouldn't be too too hard to fab up, with some "aerobraze" or TIG welder (which is purportedly not as strong as the braze!) and various parts of things to build up the given shape. There are guys, VERY talented custom builders, who've done their own RCB builds, custom frame welding, etc, over and over, and they just can't find the dry sumps anymore, so they're building up wooden models and looking to cast the parts for machining. Heck, I think that a constructed sump might just be better! We'll just have to see, I guess....
Anyway, enough ranting about the DOHC and MY HORRIBLE LIFE, and style considerations for the DOHC build as well as my hair. You don't wanna get me started talking about my informal hair salons I used to do for my ex and the kid and the kid's friends. Never mind dye jobs and cuts and styling, talking about eighteen hours worth of braiding corn-rows. You want me to sound very very gay, you get me off on a tangent and bring out my inner "Ru-Paul" hair dresser persona. Damn. THAT'S where all of the time went, that I wa supposed to be spending on the bike. Well, that and bike 'F-orums.
In any case, anybody who's thinking about doing a wire wheel swap, I hope you'll get to see my finished thread really really soon, rims and spokes on order, looking for some scrubbed tires to sit the build on so I can have fresh rubber when I start it up, don't wanna lose out on that shelf life!!! But yeah, should be loads of pictures to come.
-Sigh.
It's a forum not an English class.
You need to get to the point and not post so much your the only one who will read it (I didn't get past the first 5 words)
BTW, you don't get paid by the word, what are you trying to prove?
