cut off muffler
duggyb
where are the skis?
so i rode the bike like this last year because i didnt want to tear into it to deep, but the previous owner had welded a tractor muffler on the 2into1 and it looks really hideous, will i do any harm to the bike by just cutting off the muffler and having it come out straight? its pretty loud as is with the tractor muffler, but honestly makes it sound like a tractor hahaha
Thanks
Dustin
2into1 should work better than if it was a single but as OpTiCz says, baffles, you can pick up long tuneable ones from ebay (over here in the UK anyway)
i like, it it made me smile :)
have fun....
Not sure which bike you have, not you could just buy a replacement mega phone if your pipes are good.
http://www.macperformance.com/store/category.cfm?SID=3&Category_ID=1455
Sent from my SAMSUNG-SGH-T989 using Tapatalk 2
What size is it? I have a 360 with the same two into one and i pulled the old muffler and replaced it with a piece of angle pipe... sounds pretty good to me at least
You could order a carb kit from somewhere like carbjetkits.com and just rejet your carb. Cutting out the baffles will allow more air to flow into the carbs(air out = air in), which will require more fuel in order to perform properly. If you feel uncomfortable working on your carb, I'd do what OpTiCz said and just get a replacement megaphone.
i am comfortable working in the carbs, i was actually just going to order carb kits as i will be tearing them down and cleaning them before i start riding, last year they had some floats stick and some hesitation at certain RPMS so i know they need a rebuild or atleast a good clean.
im also debating about just biting the bullet and buying mikunis, so i can put pods on reliably.
what's stock jetting? what jetting would i need to go to? do i need to change pilots and mains? just mains?
this is assuming i cut the muffler off and ad just a angled piece of pipe.
I don't mean to promote carbjetkits.com so much, but they have a jet kit calculator that will give you a pretty good idea of where you need to go as far as sizes. You may only need to change the main. On my 94 cb 250 I removed the airbox and cut all the baffles out, and had to shim the float needle with 2 shims and up both the main and pilot jets to 135 and 42. I would suggest at least going up one main jet size. I'm sure there are posts on here about this topic by people with far more knowledge than myself, though.
I checked them out.
They seem to have no info on older bikes. Looks to be 80s and up with few exceptions.
