cutting into handlebars?
brewtown16
what, me worry?
just got my Tarozzi low rise clip ons in the mail a couple of days ago, and i need to cut the holes for the wiring in each bar. i dont have any carbide bits do they even make them for a dremel? ---for doing this- how did you guys do it?
I do believe they make it for the dremel... However, that being said,... I never drill/route my electrical cables into the handlebars like they do on stock bars.
It makes it easier to change the bars later if I change my mind on the set-up.
yeah i just drilled out the side of the controls allowing the wires to squeez out inbetween bars and the control
With clipons, there's hardly any point to routing wires in the bars being that they're so short. You're not really hiding anything.
So yeah, you should grind out notches if you need to in the control pods to allow the wiring to run outside. I have drilled bars in the past, but they a) weren't clipons and b) my control pods were NOS from Honda. I couldn't bear the thought of grinding them.
