full on tin
Active Member
Sketched this in Photoshop about half way into the build. I'm sure things will change along the way.
Check out whats done so far.
BF_CX5_sktwht_SM by full of tin, on Flickr
Just rolled into the SEC Shop... you know the drill, strip down.
IMG_4066 by full of tin, on Flickr
IMG_4069 by full of tin, on Flickr
IMG_4238 by full of tin, on Flickr
-Milled down the bar posts and plugged w/ brass acorn's
-Routed Choke through neck...Turned a new knob in solid brass.
-Ignition relocated (see below)
-Center Speedo
-33mm Clip-Ons
IMG_4354 by full of tin, on Flickr
Shave Big-o fuel door down to a clean little turn cap.
IMG_4720 by full of tin, on Flickr
Fuel sight off to the left. Won't stick into you while hugging the huge tank. easy to glance at while rippin' it.
IMG_4799 by full of tin, on Flickr
IMG_4795 by full of tin, on Flickr
Stocker tank had kneedents...but they didn't stand out enough for me.
a mix off hammers and post working. (wish I would have used some nice planishing hammers)
IMG_4301 by full of tin, on Flickr
IMG_4342 by full of tin, on Flickr
Slim Seat: Drew a CAD file, then plasma CNC cut in 18gauge Steel. mega time saver.
add ~0.75" Foam and sew up a read leather saddle.
IMG_4807 by full of tin, on Flickr
Start of new control center. Rough mock-up.
IMG_4841 by full of tin, on Flickr
-Center Speedo
-33mm Clip-Ons
