CX500 PartII
Painted a tank badge and the two engine badges, the orange needs another coat or two and I may use this as the test one (I have 3 in total) and maybe paint the orange over silver next time so it pops a bit more, I'll see how it looks after some more paint. Pretty happy with them so far though.
Cheers
Steve
Decided I needed better rubber for the rear and wanted to go a bit wider, I could have gone to a 16" wheel as the CX Custom ran those and it's wider than my 18" wheel so fill fit a 130 but I wanted to go for more modern sizes and wanted a 17" wheel. Ended up ordering a GL1100 17" wheel which I can then take apart and bolt on to a CX500 hub to give me a 17" rim that is 2.5" wide instead of the stock 18" 2.15" wide rim. This will let me run a Pirelli Sport Demon 130/80 17. Got the tyre now I need the wheel.
Here is the new tyre (130/80 17) compared to a stock rear tyre (110/90 18), should work well with the 110/70 17 front end :) And it'll look good to.
Cheers
Steve
Steve F said:
Yep, was thinking model paint is the way to go and hope to get too it this week some time :)
Don't do this. Those model paints are not designed to be durable. All you need is a plastic-safe primer, allowed to dry very well.
Cheers
Steve
will it fit? I though CX's had clearance issues.
130 80 17 will fit fine stock is 130 90 16
a 140 90 16 will not fit on a stock 500 swingarm and 80 might but it will be close
you can get a 140 on but you have to rework the swingarm and the distance collar
easier for me to fit a gl650 swing arm then 140 fits easy and a 150 is possible with some fiddling
Wheel showed today and it's looking good, should be a case of swapping the hubs and calling it done
GL1100 wheel just sitting on the tyre to get a feel for it...
Looked good by eye so I took some quick measurements to check the hubs were indeed the same size externally, you can see the GL axle is heaps bigger.
CX500 bolt spacing on hub, approx 90mm
GL1100 bolt spacing, same as the CX
CX500 Hub size, Approx 150mm
GL1100, the same, it's sitting proud of the hub so looks a little wider.
The extra width and 17" diameter is going to be very handy
Now to pull them apart and build the bastard wheel
Cheers
Steve
have a blast steve
ream the holes to exact size as you install the hardware
snug the hub up then the outer spoke plate
i use a truing stand to check the wheel as i do final torque
here is a post i did on this
http://cx500forum.com/forum/cx-customization-modifications/21413-18-inch-rear-wheel-hard-way-3.html
TheJester said:
What did you do to modify your heads?
I love the CF rear fender.
Just matched the ports to the inlets and gave them a refresh, they dont need any more than that but it lets you squeeze every bit of power out of them without doing more extreme modifications.
Cheers
Steve
Pulled apart a GL1100 wheel today so I can mount it to a CX500 hub and fit the fatter 17" tyre. When the bolts I ordered turn up I'll strip down the CX wheel and swap the hub into this one.
Cheers
Steve
I have to believe that the CX Cafes are the most improved looking "regular" projects. Your bike is simply stunning, the originals, not so much. I loved it Naked and even more with the fairing. I trust the GL wheel will enhance the looks and handling.
The GL1100/CX500 wheel combination means the rear tyre will be a 130/80 17 making a better match to the 110/70 17 front tyre. It should handle better and also look better :)
Cheers
Steve
Steve F said:
Postie brought me some fun stuff today :)
Also brought me some of the stuff I need for the RFID ignition system to get rid of the key, spent some time sorting out a wiring diagram, it'll work fine on the CX and probably any other Honda that grounds the kill switch wire to cut power to the CDI.
Cheers
Steve
Hi Steve. Sorry to bring up an old thread, but I'm thinking of trying this on one of my bikes. So cool.
My question relates to the kill switch component, and your version of grounding the kill switch wire? On all the old Hondas I have, the kill switch interrupts the power to the coils from the black (switched power), and is not grounded.
Could I adapt your circuit to work this way by feeding the black to the black/white (coil power) through the relay instead.
Love your bike with the fairing fitted.
Cheers
Ian
Sent from my iPad using Tapatalk HD
Don't see why that wouldn't work, in saying that though if you just cut the main power (via the RFID) there is no real need to wire the kill switch through it anyway, I just did because it was easy enough to do :) At least I think that's right, it's been a while since I looked at it.
Cheers
Steve
Steve F said:
... in saying that though if you just cut the main power (via the RFID) there is no real need to wire the kill switch through it anyway, I just did because it was easy enough to do :) At least I think that's right, it's been a while since I looked at it.
Cheers
Steve
Yeah, that seems like a handy way to approach this. Electrics aren't one of my strong points, so happy to accept all options. Seems I could get away with just switching the main power and light power, which would mean I can just plug and play with a new sub-harness I could swap out for the existing ignition switch plug.
Thanks mate
ian
Bastard wheel (GL1100/CX500) ready to be bolted back together :) Looking forward to slotting it back in the swing arm.
Cheers
Steve
