CX500 questions.
Staffy
It's not yours 'til you cut it up.
I've been looking around for a while for another bike and i've found this CX500 in what my local breaker calls "The Graveyard".
It seems to be all there (the important parts anyway) but i was wondering from those who've owned them what to look for. I also need to know if this is a breather and where it goes internally:
The engine has been sitting outside for a fair while and is all sealed except for that breather. Opinions?
the cx500 is where i got started with bikes. the biggest thing to look for on these bikes is the stator. they are the weakest link on these bikes along with the CDI (years 78-80) the 81-83 had a much improved ignition system. If your interested, go the www.choppercharles.com there you will find every and anything you want about these bikes. but the only other thing besides the stator and CDI would be the cam chain. Really any year after the 78(first year of the bike) i would go for. they 78's had problems with the cam chains.
here are some links to do some tests if you want
http://www.elsham.pwp.blueyonder.co.uk/cx500/stator/
http://www.elsham.pwp.blueyonder.co.uk/cx500/tappets_cam_chain/
hope this helps
Good links needfsteed. Thank you. I may get this bike anyway, even just as a bike to break for spare when i get another cx.
Thanks heaps for yur knowledge guys. It turns out there's two CX forums out there, one of which is australian. I may have to trawl around there for a while.
I have a couple in the storage yard. I understand the water pump or an associated seal can be a bitch at times. I have also heard that the 650 version of that engine is significantly improved all around. To that end I have one to go in one of those bikes eventually.
all the 650's got stronger parts.
650 motor was based on the CX500 turbo which had a lot of improvements over original design
PJ
