cxman said:make sure when you put the connectors on you do a good job crimping them and use dielectric grease when plugging them
together or it can burn up
use a factory or equivalent thickness rear cover gasket and check that the shifter shaft spacer shim is between the shift shaft
and the block
test for for proper shifting as you put the rear cover on
if you use a aftermarket gasket and its to thin it will jam the shift linkage
You have a picture of this spacer shim? I'm not sure what you're referring to.cxman said:make sure when you put the connectors on you do a good job crimping them and use dielectric grease when plugging them
and the block
cxman said:part number 20
http://www.hondapartshouse.com/oemparts/a/hon/506f7e83f8700229747b8868/shift-drum-shift-fork
as to the smart phone or thick fingers the answer is yes
Sweet! Thanks!AlphaDogChoppers said:I have a CX500 apart right now. I'll measure the washer for you.
