D-Sub connector for CB350 tail lights?
72texas350
I am setting up my CB350's new LED tail light I made in the seat and I'm trying to make it easy to connect and disconnect the light so I can take the seat off easily. I have one seat done that is a cafe style seat and I am making another that is a brat ish type seat. I'd like to be able to interchange them pretty easily. Is there any major issue with using a male d sub connector on both the seats and a female connector on the bike? I ask just because I already have extra d sub connectors.
Go to Radio Shack (or electrical supply) and get a 3 or 4 way connector set. this way the wires hook up to the right places everytime. You need 3 wires for the taillight. Taillight 12V, Brakelight 12V, Ground.
Or even better, go to www.vintageconnections.com and get a GOOD crimper and bullet connector kit. In addition, they have 2,3,and 4 pole japanese style connectors (Nylon) like stock. they will work well and look OEM.
The kit will have extra parts so you can properly fix any other connectors that go bad.
D sub connectors that I have can only be connected in one way, so I don't need to worry about plugging them in incorrectly. Also, these are 15 pin connectors, so there is plenty of spots to hook up. I actually have 10 wires because of how I set up the lights (one set of lights on each side for the brake and running lights then another set on each side for the sequential turn signals.) I'm not too worried about it looking OEM because the majority of the bike is not OEM, and the connector is hidden under the seat.
I just was sure if there was anything I need to worry about with the d sub connectors in turns of how much power can go through them and things like that.
Your talking VGA connector...O.K. But they aren't big on current. An LED or 2 is fine, but nothing with real current.
Thought you meant a 1/4 Spade connector. Some call it a D connector.
Use gold plated ones, or corrosion will be an issue over time...
