I recently installed the same setup in my 1976 KZ400. My advice is to write down on a piece of paper the list of all the wires for the speedo/tach. Then take a look at your factory wiring diagram and figure out the color of each wire that performs the same function. Then write that down on the same line on the right side of the paper. My Example:
| | Tach/Speedo | Factory Harness |
| Blinker + | Yellow | Brown |
| Blinker - | Yellow/Black | Orange |
| Oil + | Red | Brown |
| Oil - | Red/Black | Red/Blue |
| Neutral + | Green | Brown |
| Neutral - | Green/Black | Lt Green/Red |
| Hi Beam + | Blue | Black/Red |
| Hi Beam - | Blue/Black | Black/Yellow |
| Speedo Backlight + | Orange | Blue |
| Speedo Backlight - | Black | Black/Yellow |
| Tach Backlight + | Red | Blue |
| Tach Backlight - | Black | Black/Yellow |
If you have two wires going to the same place (like neutral light bulb) and you're not sure which is positive and which is negative you can use a multimeter to figure it out. Keep in mind that there may be things like common (switched) positive wires, like my brown example above, and common negatives, like my black/yellow above. But you ought to be able to figure that stuff out from the factory wire harness diagram.
Next you'll want to simply connect each of the wires that you have on the same line.
Couple of tips:
- Use a factory connector if there is one. For the early KZ400s there is a 9-pin connector (6-pin connector in later models) inside the headlight bucket that connects from the factory harness to the harness for the tach/speedo. Rather than cut out the connector and use separate bullet connectors for each wire or solder each one individually I chose to cut off the connector from a spare stock tach/speedo that I had (make sure to leave enough wire to solder on the new ones) and soldered the wires from the new tach/speedo to the connector. So it looks somewhat stock, all the wires are in one place, and it will be easy to disconnect and go back to stock or to a different tach/speedo in the future. If there is not a factory connector, I don't know much about Hondas, then consider buying one and using that instead of individual ones.
- The tach and speedo have a lot of extra wire that you won't need if you're going to stuff it into the headlight bucket. Figure out how much you'll need and then trim it back. You won't be successful trying to stuff 3 feet of wiring harness into the headlight bucket. I know this from experience.
- In the case of the KZ400 there is a turn signal indicator alarm in the area of the headlight bucket that makes a buzzing sound when the turn signal is on. I removed the buzzer a long time ago but still had the wiring in place. I was able to use this to connect to the blinker wire (yellow) of the speedo. If you don't have a single wire for the blinkers then you'll have to use a diode in between the left/right blinker and the yellow wire for the speedo. Check out the comments on the speedo on the DCC site for details. I'm sure Sonreir can provide more/better guidance once you get that far.
Best of luck to you.
