've been struggling with backfiring on deceleration. I've known that it's due to lean conditions especially at idle. I've been advised to either bump the idle a bit, change the idle mixture. or get a bigger pilot jet. Then I came across this posting
http://www.motorcycleforum.com/showthread.php?p=504548
In the middle, he describes the process for rejetting a CB350G (which I have). The interesting part was this
Low or SlowSpeed Jetting
Now you can tune for low end performance. If you are getting a poor jump or hesitation off the line, or a lot of backfiring on deceleration, then you need more fuel through the pilot jet. You increase fuel flow through the pilot jet by turning the pilot jet screw OUT a half turn on each carburetor. Do this until you get the performance you want and/or there are no back fires on deceleration. If you go more than 5 or 6 FULL turns out, you will probably have to install a LARGER pilot jets. Larger pilot jets are usually needed if you have removed the stock air intakes and surge tank and installed K & N filters which dramatically INCREASE air intake volume.
That was an aha moment. I'd been under the impression that the pilot jet screw, referred to ambiguously as "air mixture" worked the OPPOSITE WAY. That is, that opening it up allows more air. Instead, opening it up allows more fuel. Maybe I was just being stupid, but more than one place has implied this. Anyway, i did what it said, opened up this screw on both sides (actually 1 full turn). I then had to adjust the idle so it ran at 1200, and voila NO MORE BACKFIRES. I also added some SeaFoam to the tank, so that probably helped too, but the response was immediate after the idle adjustment.
Now all I have to do is figure out how to get more fuel when the throttle is wide open. But since I'm getting some pipes that i think will have a bit more backpressure than what I have (requiring another reset probably of the pilot jetting) I'm hoping I won't even need to get new jets.
