did i really just do that?
jmal18
Active Member
I have a broken kill switch on my cb350 and I was toying around with it. Read about connecting the contact points and running without a kill switch and I accidentally touched the two points with the screw driver and everything went out. No gear indicator light on my tach, no horn, no headlight....what the hell did I do and can I fix it????
djelliott said:
Yinzer is correct. 15amp I believe.
15 amp is correct.
i get the feeling you blew the fuse by shorting the system out. if your bulbs arent blown or anything, then its probably just the fuse.
Sounds like it may have been modded. On the 360 (can't remember the 350) it's a square plastic box mounted under the seat with 3 bullet type fuses in it. Look for a red wire, that wire runs to the fuse box. If it was modded, the PO may have swapped the fuse box out for blade fuses or (GASP) bypassed the fuses altogether.
The 360 and 350 are completely different.
On a 350 there is a single inline fuse, under the seat, near the battery. It a little plastic tube with a wire running through it. Pop it open and youll see the fuse.
That I do have! Thanks for the help...will take a look at it!!
VonYinzer said:
Cool... And please invest in a manual. It will save you TONS of time and headaches down the road.
Headaches is something I am definitely up for avoiding!
