Difference Between 71 CB450 and ?? CB 500t front forks?
Garage_guy_chris
Ok I found a set of unknown year CB 500t front forks at a swap meet, I knew because they were in a box with other unmistakeable CB 500t shit, now the fork tubes are in really nice condition, meanwhile my CB 450 have pitting and rust at the triple clamps, there the same diameter so i was thinking of switching them out but.... the brake caliper is different, and the fender mounting is different. It doesn't look like the 450 fender will bolt on?
So questions
- Internally are they the same or different? the fiche is confusing and shows them differently, which makes them look very different?!?!
- Which forks will have the better performance?
- Could I use the 500t legs and use the 450 lowers ?
- Would i need a CB 500t fender or is the 450 mountable? (im sick of working on it, i wanna ride it....)
- Is either brake caliper superior?
I know this is an old post, but I was wondering if you ever found an answer to your questions? Specifically if you can have the 450 lowers matched to the 500t fork tubes and any fender issues?
Thanks in advance!
if they are early 450, they have bushings on the bottom, and are completely different from everything else.
if im not mistaken, late 450 and 500 stuff are the same, as well as the CB750, etc etc... fork tubes are all swapable, just different lengths.
Well the 450 forks are pretty far gone, alot of rust pitting on the upper fork legs so they have been retired, I decided to go with the 500t forks and just finished breaking them down and rebuilding them, also polished the lowers up nice, Got a 500t fender off a member to use and going to use the later brakes that came on the 500t forks
My fork tubes had some minor rust spots, I found some maroon scotchbrite lubricated with kerosene cleaned them up A1
