Difference between Honda 350 & 360 engines
jbake515
I know the 360 is a 6 speed and the 350 is a 5 speed. Is the only difference in the bore? Are the cases interchangeable?
the valves, valve springs, retainers are all interchangeable, I believe the oil filter is the same, starter motor, starter clutch and alternator rotor and stator are also the same I believe.
check the part numbers on the clutch assembly, it's probably the same too, honda used a lot of the same parts from the 350 production to make the 360 less costly to produce
