drduke
Hi, any help here would be appreciated....I purchased the below mini tacho for a Honda CB400T Hawk 1978 Chassis number CB400T - 2050159,
wired as per diagram below..however at idle the rev counter is stable but when you apply throttle the dial hops all over the place. I have checked with the supplier, and the tacho is suitable for the model..i did post this yesterday, but somehow the thread went missing this morning.
I received this response form mydlyfkryzis, but was unable to reply so thanks anyway.
The text of the reply is shown below:
The CB400 is a 360 degree engine. The single coil fires once per crankshaft revolution. (For contrast, My CB360 coil fires once per 2 revolutions).
So, let's do the math. Hz = Cycles per SECOND, RPM= Cycles per minute.
So, at 1000 RPM, your coil is firing 1000 times per minute. Divide 1000 by 60 (to get how many in a second) = 16.666 Hz.
So you have the right Tach as far as H.
Are you sure the green wire is on the ground side of the tach? That might be an issue,
I had wired to the green wire to the ground side of the coil...but this is earthed straight to the chassis, so with red wire to live on battery and green to earth...how will it pick up a signal? when i connected the green wire to the live side of the coil, the needle on the tacho went from zero to eight, and back to zero and stayed there until you start the engine...then it hops all over the place ...HELP???
