AgentX
Over 1,000 Posts
So, I installed a headlight relay on my bike when I put in a single-beam HID a year ago. Was concerned that the startup draw of the light would be ungood for my bar switch, and thought the power needs might be better met by a run of 12 or 14ga wire straight to the light.
I'm now rebuilding the bike now, and going back to an H4 bulb and using a brand-new bar switch. I have 16ga wire I'm planning on using for as much of the build as possible, with a 60w bulb.
12v system means I should have 5 amps going through the wire with that bulb. (right?) Online chart tells me that 18ga is perfectly good for up to 24 amps over 5' of wire, and I'm running 16ga. I will be running a fuse block power distribution panel. (So...10 amp fuse should be plenty to protect my wires right?)
So is there any real reason to build in a relay, or should I just power straight through the switch to the headlight? My priority is durability, so I don't mind the slight additional complexity if the relay helps somehow with that, but in general to me, simpler with less componentry seems more durable at the same time.
