I'll tell you how I did mine, this is by no means the end all process, just that I've had great success with it.
The Seat pattern.
Get the blue or pink insulating foam from Home Depot. Cut and roughly block out the shape of the seat you want. Take a bread knife and a surform (hand held cheese grater, auto section by the bondo) to get it closer to the shape, then sand it smooth with sandpaper. Florists foam will work okay, but I find that they regular ball type Styrofoam a PITA to work with and it will never be smooth. The insulating foam you can sand till it's perfect but be careful that you don't slice it with an edge of the sandpaper.
Prepping the foam pattern:
Cover with aluminum foil, tin-foil tape or paint it with latex paint. I opted for the latex paint, but brush it on. Don't use a spray bomb that will eat you foam pattern. A couple of heavy coats should do it. (The procedures protect you from polyester resin from dissolving your pattern)
The fiberglass
I used what was on hand, had a racing buddy you gave me a huge roll of chopped mat. It's about the weight that you can buy in the autostore. That's all I had so that's all I used. There are lighter weights of mat and cloth. The lighter ones work well for tighter shapes. Use what you can afford.
The Resin
I used polyester resin found common in auto stores. Epoxy resin is said to be better but for me it all came down to price and availability. I read on a few boat building blogs that you can cut the resin with acetone to thin it out. This helps to wet the glass out quicker and slow the reaction down by a little bit for more working time. Don't go above 10% acetone otherwise it won't kick off. So 300ml of polyester resin = 30 ml of Acetone. Mix the Acetone and resin first, make sure it's mixed very well, Then add in the catalyst to start the reaction. If you don't pre-mix the acetone you won't have enough time to mix it properly before the reaction kicks off.
The process
Prep a flat surface with sheet of waxed paper taped to the surface, get a pack of cheapo brushes, pre-cut pieces of fiberglass and trial fit them to shape on the pattern dry, make sure you know what piece goes on to what part of the pattern. All pieces should have some overlap to them.
Mix your resin, resin+acetone=mix then resin/acetone mixture+catalyst
Lay out a piece of glass on the waxed paper and with a brush, stipple the resin onto the glass and when wetted throughly put on to mold, Repeat. I found that I didn't use as much resin this way as laying the glass dry on the pattern then brushing resin on. Keeps the part lighter as well.
Keep doing that till you have as many layers you feel necessary to hold your weight. You can also encapsulate hardware and other things like wood strips as a place to staple you seat cover to during this time.
Long winded but I hope this helps.
