joevirus563
Coast to Coast
Any advice? Looking for maybe copper gasket so let me know what you guys think.
They are most after bolts...
crazypj said:Yes, but leave the bike one alone ;D
crazypj said:leave it alone, it's not as simple as just milling it.
None of the marks are particularly bad and no where near a high pressure area
JRK5892 said:copper gasket and your cool man
JRK5892 said:depends on the gasket, what was there stock? the larger the gasket the more of a gap you have on your heads and less power you will make
Permatex make one of those: http://www.amazon.com/Permatex-80697-Copper-Gasket-Sealant/dp/B000HBNUDQJRK5892 said:there is a spray you can coat them with that will help it is a copper gasket spray actaully. does well i would not permatex in there at all
JRK5892 said:ok solid we are on the same page, i thought you where talking about the gasket maker like the "right stuff" cool then you are good to go just make sure the head is clean i wipe them down wiht non clorinaged brake cleaner first
crazypj said:I use the copper spray
Hang head gasket on a wire and spray it :
PJ
