Doing away with stock start/headlight button. Cb750F
Loctite77
Yeah Son!
So I am putting new controls on my 76 CB750F. I am aware that the start button kills the headlight when the starter is engaged so that all of the power can go to the starter. I am replacing with a small simple momentary push button with two wires. So I will only have the ignition switch and the push button. Two questions:
1. Is there a way to kill the headlight at start up without installing a toggle switch?
2. The new push button switch is rated to 3V max. I assume I will have to put a delay between the switch and the starter solenoid?
Thanks!
1.) Yes. A five pin automotive relay. Pin 87a to the headlight dimmer switch and pin 87 to the solenoid. One wire on the new button goes to a black wire in the harness along with pin 30 of the relay and the other wire on the new button goes to pin 85. Pin 86 gets grounded.
2.) I'm assuming you mean 3A, not 3V. And yeah, that will be fine if you use the relay.
So one relay will accomplish both? Turn one device off (the headlight in this case) with 87a and also kick on the starter?
This is where it gets funky, my headlight Hi/low is controlled with a single momentary push button using a switching relay. So do I run 87a to the same pin that the momentary switch is hooked to? Is that going to create problems? Thanks.
Yeah Son!
Yes. One relay will handle the solenoid/headlight thing, but it won't work for the high/low on a momentary (unless you want to hold the button down the whole time for high beam).
I think you misunderstood me. There is already a momentary with its in switching relay installed to switch back and fort from hi to low beam. So to wire up to kill the headlight as stated where do I run the wire from pin 87a? Thanks for your help.
Yeah Son!
I'm thoroughly confused. Will this work?
Yeah Son!
I think you want to place the new 5 pin relay between the existing latching relay and the power source. In the diagram above, pin 87 should go to the starter relay, 87A to the headlight latching relay.
Thanks in advance for when this is figured out ;D Was needing the same dealio but for a right side starter switch from a donor R6 control set :o
How does this look then? If I understand correctly 87a has constant power except for when the switch is activated to kick the starter so if I go from 87a over to the switching relay that operates the hi/low I should be good and the headlight will go off during startups?
Yeah Son!
Yup, correct. It should actually diagram what pin is normally open and normally closed on the relay. I'm going to be doing the same thing actually, but without the the dimmer relay.
You need at least a 70amp relay for starter circuit, the normal 5 pin automotive store ones are only rated 30amp
Thanks for the heads up brother. So far it is working just fine but I'll go ahead and pick up a 70amp one so I don't fry anything.
Yeah Son!
30A is fine for switching the power to the lights and such. You shouldn't need more than that unless you're using a relay for the starter motor, itself. Stick with the solenoid for that.
