ThomPa
Modelled up a 12mm spacer to offset the rear sprocket. After that I printed it on my Ultimaker 3D printer.
It's designed so that the spacer bolts up to the hub and the sprocket bolts up to the spacer. In that way (me thinks) there won't be any excessive strain on the bolts caused by the 12mm offset.
But after talking to the CNC guy (who is into karting) he said most of the force from the sprocket is exerted on the little lip on inside of the sprocket. So I could just use the original 6 bolt pattern and put the spacer in between without any problem.
Any thoughts on this?
