Double Outlet Petcock
djg42
does anyone know where to find a double outlet petcock thats not too much money? This pingle one can be a universal fit with the an adapter plate but its $116,
http://www.z1enterprises.com/Petcock--Pingel-HighFlow-Fuel-Valve--DOUBLE-OUTLET-28.aspx
What tank is it going on? Honda makes a few dual-output petcocks - most/all of the SOHC4 engines had 2 fuel lines going to the bank of carbs off a single petcock.
Its going on my GS450. The stock petcock had one fuel line which went to both carbs, down low near the float bowls, but I put on VM34's and its hard to get good fuel flow to both carbs from the stock petcock. The Vm34's fuel port is on top of the float bowl and there's very little clearance between the petcock and the carbs so i think a dual outlet petcock may make things easier.
I have tried lots of different figuration with the fuel lines but it still isn't supplying enough fuel for sustained highway speeds.
pfoee. tricky one.
My first thought is that the smallest in diameter is the t-piece, holding back the flow. As you stated, therefor a dual petcock would be better.
Other (kinda redneckish - and sice you have the vm's on i dont think you'll go with it) plan is to use a hose bigger in diameter to accomodate a t-piece with bigger holes. It would be as follows:
petcock -> small diameter hose -> big diameter hose over the small hose -> t-piece -> big diameter hoses -> small diameter hose in the big ones -> carbs. I know from experience the "hose-in-hose" technique works without leaking when ID (big hose) and OD (small hose) are same. You could atleast try it to see if the small t-piece is the problem.
p.s. dont crank the clamps on those pods so hard ;)
p.s. 2 - have you checked the filter in the petcock? could be clogged up restricting fuel flow.
Something doesn't sound right IMO. Just because you swapped carbs, they alone shouldn't be sucking so much gas as to starve the carbs. If you look at the tube on top of the petcock (inside the tank) on the GS and a dual nipple CB, I would be willing to bet they are almost identical.
I'm with Bert on this one - dirty petcock filter, slightly clogged tank vent, etc.
You did re-jet for 450?
It shouldn't be flowing enough to drain bowls unless something is blocked.
Have you tried fuel flow into a gallon can?
It canshow you if tank vent is blocked and/or fuel tank filter
Thanks! I checked the flow from the petcock and it seems strong. I cleaned the filter and petcock up, Im going to put it back on today and ill see how it is. I also got a bigger fuel T, so ill see how it is with that, thanks!
Dennis
Yeah I'd be surprised if your 450 could suck the pair of VM34's dry, even with a single fuel line supplying both carbs.
At the end of the day, the needle valve regulating fuel flow into the bowls is smaller than any of the hoses/t-fittings you have between the carbs and petcock, so it's not likely the size of any of those bits.
Have you checked the float height?
