I've been looking at an auto tensioner solution for my CB, however the case simply isn't big enough to accept one, so I set out to make a manual tensioner, which would remove the need for the locking nut and also mean the issues in the springs not having enough tension would also not apply.
I'd seen some options around on the interwebs and so set about trying to make my own. First step was to take a trip down to my local bolt shop, for a selection of stainless bolts in a few sizes (as I didn't know exactly what I needed in length) in M8 and M5.
The plan was to drill the M8 out to thread it for an M5 bolt.
First up I popped some round stock in the lathe, threaded it for M8 so I could use it to mount the bolt. I was surprised to find the hole was not centred, God knows why, so instead I used some nuts to mount the bolt in the 3 jaw and it turned out to be a much better solution:
I used the lathe chuck to start the thread cutting so it would be straight. Then finished it off by hand:
The original plan was to have a thread the length of the bolt, but my M5 tap was starting to bind about half way, so I drilled out the far end to 5mm and kept the thread to about 20mm down the bolt to reduce the risk of snapping the tap. I also faced the front of the bolt so it would seal better:
All done so far, plus I have a copper washer kit coming too so I can seal it all up:
Not sure what the original owner of the bike had done to the bike, as the thread to the tensioner arm was pretty wrecked, so I tapped the thread to tidy it up. Turns out the main M8 bolt was a little too long as when I put the tensioner arm back in, the flat section was not being seen through the front locking bolt hole. I assumed the flat section should be all visible (to the point where you can see where it's not flat), so I took the bolt to the lathe and trimmed it right down to increase the range of movement for the tensioner arm. Here you can see how far down the arm goes:
All done with the bolt tightened down on the case. Plenty of adjustment on the manual adjuster:
However I still think I need a bit more adjustment as this is as far down as the tensioner arm will go:
