spotty said:you could take a leaf out of hyosungs book and make up a pair of plates with several sets of mounting holes, weld them on and move the pegs around to suit
neevo said:The pedal contacts the rear brake pivot point. Not overly concerned as the pedal shouldn't come this far up when set correctly:
What have I done wrong?
neevo said:There's only 1 of those sleeves and I assume it acts as a stop for the lever coming up too far. You make a good point though, I could add a spacer behind each of the bolts to bring it out 6mm or so.
Thought I might have put it all together incorrectly.
neevo said:I've got a few parts that have come in but will detail them when I get back into the shed.
Quick question about cam chains. Bought one and now thinking I have have ordered wrong. Anyone care to set me straight?
This is the description off eBay, will this work in my '76 CB400F Super Sport?
"GENUINE JAPANESE DID CAM CHAIN TO SUIT THE HONDA CB400 F1 & F2 FOURS FROM 1975 UP TO 1979.
THIS CHAIN WILL ALSO FIT THE FOLLOWING
THE HONDA CB175 TWIN 1974-1976 & THE CD175 TWIN FROM 1971-1978.
CHAIN SPEC IS TYPE 219T ENDLESS WITH 82 LINKS, IF YOU REQUIRE A RIVET LINK FOR THIS JUST PAY £1.00 MORE & WE WILL SUPPLY THE 219T DID RIVET LINK WITH YOUR PURCHASE."
Evil August said:Have you messed with your rearsets anymore?
crazypj said:Did you get rivet as well?
219 is pitch between pins and width, 350 is same as 400f
I use CB750/CB350 length and shorten it for 360
