Sonreir said:
I think it's this guy? Only an hour drive from me if you want me to handle shipping stuff, neevo.
http://www.vaporblasting.biz/
There's also this guy:
http://www.dotheton.com/forum/index.php?topic=53266.0
The first one, Jeff Gibson, is who I use. He is a sponsor on my bike. The problem is not handling the shipping, it's the high cost of send a whole motor's worth of parts.
How would shipping to you then getting it to Jeff help him?
o1marc said:
This is who I use for my Vapor Blasting. Excellent place if you are on the west coast. They are in Ore. He says he won't do "multicylinder" motors but I think he means more than twins. It's because he is tired of cleaning the dirty shit people send him. If you make sure your parts are clean and tell him I sent you he should do them for you. I think his pricing will get you for less than the $250 you quoted.
http://www.vaporblasting.biz/index.html
Pretty sure the shipping to and from Australia will bump the price by about double the blasting cost, even 'empty' motor is pretty heavy, $600~$700 would probably cover shipping both ways ::)
Too true PJ. Might make it a little out of my budget range ;)
For those in Sydney looking for a vapour blaster I can highly recommend Dave Mac at vapourblasting@yahoo.com.au, he's a fab chap to talk too, his pricing is in line with US pricing (which is unheard of in Australia), he's got an amazing reputation and if you all wait 4-5 weeks I will have pictures of his work too!
Hi Neevo, been reading your thread and its very inspiring due to what i want to do with my bike! I was wondering where you got the swing arm brace for yours?
Thanks!
Thanks!
If you have been reading you would know he got out the bender and welder and made it himself.
Detailed post on May 11 about the build.
Correct. I made a template from scrap tube I had lying around here and used that to give to a local tube bending place. Then I welded it up myself.
Still have a spare brace here as they used up the stock by making 2.
Came here today to get update on the project and ended up going over the whole thing ;D this is a Honda I can vote for 8) most buy a nice old bike and fuck it up you sir buy a fucked up bike and make it nice ;)
Awesome, ill have ago with that!
Where abouts are you holbrook? If you are in Oz I would sell you the other brace cheap, failing that I can measure it up if you want so you could simply get a copy made wherever you are on the globe.
Anyone know what Honda models share the oil gallery plugs? I want to replace this one (and maybe others) as the head on the bolt is mushed up (and I would like a nicer looking one) and I plan on removing all of them before I have the motor vapour blasted so that I can ensure I can flush out all the media afterwards (so will need to replace others if they get damaged in the proces too). I assume there are 4 of these (2 on each side and 2 at the front?)
That's probably the same as CB750, 500, 550, 650 plus probably a few others.I have seen aftermarket billet ones but I considered them too expensive (plus can't remember where. maybe TTR400?)
Just looked on Kevin's site and he's got all the other covers but not the oil gallery ones. There are options on eBay for 750 though so I may buy 1 and see if it fits. Are they all the same size or are there different ones?
I can't remember but I think they are all either 14mm or 16mm thread.
The one behind generator is just a plug with 'O' ring, you should have the 'O' ring in gasket set, don't need a new plug
I just want to replace the mangled one under the points.
crazypj said:
I forget, did you ever manage to remove it?
Nope, hence why its all mangled. The plan was to cut it out somehow and replace it before I get the motor vapour blasted so its the same finish. I was planning to rethread the gallery bolt for the oil temp sensor unless you can think of a better place to mount the sensor?
Reason I was thinking there was I could run the wires up with the points wires.
Is this what I need? It lists the 350F, but not sure of the cases are the same between the 350F/400F
http://bit.ly/16uE3sx
When you chip off the outer edge it should unscrew relatively easy
It looks a bit like a mini rocker cap, (with 'O' ring) just so you know whats inside
crazypj said:
Yep, looks like it, it's generic part number instead of model specific
Bid placed! Will get cracking on removing the old one. Is this the best location for the oil temp sensor?
