o1marc
Over 1,000 Posts
neevo said:Thanks... as always
Will check out the transition and fix up if required.
Post a pic if you would. Bolt up the boot to the head and look into the opening. If there is a lip on the head showing scribe it with a scribe or other pointed tool and then just blend it in to about an inch in or less. If you open it up too much it will slow down the velocity of the intake charge. That's why the good carb boots will usually be tapered to speed the intake charge and why cheap pods rob you of power because they are usually restrictive compared to the stock boot and seldom have the taper.
