Oil pump time. As with most of my work on the bike, first up I got a well organised workspace and cracked out the Clymers manual I had. I had 3 complete oil pumps at some point but now cannot find 1 housing, main rotor set and gearbox rotor set (despite still having most of the other bits). I assume it's because 1 was so bad I tossed it in the bin, something I need to do more of as I am hanging on to literally every part at the moment (including 3 valve trains):
First I set about giving all the bits a clean with some degreaser and a nylon brush to clear the gunk away:
All cleaned and a nice workbench I set about picking the nicest parts to build 1 pump and spec the items as I went. I got the Clymers to guide me (along with a Haynes later on):
Surprisingly the specs on the oil pump are pretty limited so I checked all those and have taken a load of pics to help guide me with those in the know as to whether this pump will be serviceable.
First up is the housing. This has already been vapour blasted and I picked the one with the least visible damage. There are some scuffs inside the rotor housing but nothing that catches a fingernail, so I assume these are fine to use:
The other side has not a scratch on it and you can still see the machining marks:
The outer rotor has some scuff marks too but again nothing to major and only 1 or 2 can be felt with the fingernail, even then only slightly:
Looking inside the rotor for pot marks in the corners, there appear to be none:
The inner rotor is pretty clean except for 1 pot mark on each rotor as its obviously sucked something through:
Next up I put the rotors in the housing and measured the lobe clearance. The manual states 0.35mm is maximum and I was pleased to find only 0.09mm clearance:
Outer rotor clearance should be within 0.3mm and it came in at 0.1mm:
Looking at the gear rotor I was surprised to find these the most damaged. 1 had a visible but only slightly felt scratch, the other was scratched across the face and most were felt. I went with the one that only had 1 scratch as the rest of the rotor was clean and I thought the 1 small scratch would be better than lots of them (I chose the one on the left):
The reverse side of the one I chose was also spotless which was also the reason I went with it:
Rotors on both looked in perfect condition:
The housing also appeared fine:
The rotor gap was larger than the others at 0.12mm but well within spec:
Next I measured all the blow off springs to find the lest compressed one:
I wanted to check the other rotor before I buttoned the pump back up. On inspection the rotor had a lot more damage on the faces and it could be easily felt:
Checking with the feeler it came out at 0.12mm too so I was right to choose the other one:
Lastly I wanted to check to see if my oil pressure switches worked. So I set the tester on the bolt and body and found a slight resistance, then shot compressed air up it and found went to infinity. Both pressure switches did this so I assume that's normal (I was expecting it to close the circuit when the pressure dropped so these appear to be working, although I don't know when they will engage):
That's it!
Now all I need to do is grab new bolts all round, some new o-rings and work out where the oil passage tubes should go:
