The wife is being very kind at the moment and allowing me a couple of hours here and there to work on the bike.
I've been waiting to get the bike back before finishing off the subframe tray, but today impatience got the better of me and so I cracked out the welder, angle grinder, files and grabbed a load of old photos, to try and get the tray finished off.
First up I drilled the box for the rec/reg mounting holes, then cut out 1 side of the box to allow for the rec/reg connector block to slide through:
I need to grab some new mounting hardware, but it will do for the moment.
I did a fair bit with the hand files to try and keep some accuracy to the lines:
Here you can see the planned amount the rec/reg will protrude below the tray:
Next I cut the hole. Again I finished it off with a hand file to try and keep the gaps as minimal as possible as I didn't want to add too much weld as I was worried it would warp the tray something terrible:
Test fit with some magnets keeping it in place:
All welded up and the hole cut for the RFID receiver:
Top view:
Liking how discrete the items are from the side. It's a hint that something functional is there but not in plain sight:
I was pretty careful welding the box in and whilst I was able to control warping well, the edges were not as sharp as I would like, even after some file and dremel action. But it will have to do and hopefully blends a bit more when it's painted or powder coated:
