Drag Bars on my CB360t
motojoe
Im a long time lurker and avid rider. I have wanted a cafe projuct for so long but things have not gone as planed. I wound up picking up a 75 cb360t from the original owner with under 1k original miles. The bike looks showroom and Im not just saying that. Its too clean to chop up and mod but I need to change the bars, They sit way to tall for me. I know I can also go back to stock very easy. My question is will drag bars hit the tank when I cut the wheel, and How is comfort compared to clubmans. Any info including where to order can really help. Thanks guys! Pics too?????
Not super familiar with that bike, but on my 71 CL350, it was pretty straightforward. If it's at all like just about every bike from this period, you will have to drag the wires out of the existing handlebars and either find a way to put them in the new bars (may not be holes in new bars) or find a way to make them come out of the housing. Then you will want to wrap them in something, or else it looks like poo. Shrink wrap works well. I had to take a router bit to my turn signal switch housing to route the wires out. I also ground down a pin that was used to keep the housing from twisting up or down. You can also drill a new hole in the new bars to make it fit.
Then there is the cables to consider. They will be too long. I made my own cables, but it wasn't all that easy. It was a combination of BMX bike parts and Honda parts. In the end, it worked. I could describe it in detail, or you could check the other thread about the same thing.
So, if yours is like mine was, that's about it. That I remember.
The bars didn't hit my tank, and I was rewarded with a slightly more comfortable position. And non rusty bars.
My dad is going to be using the bike too when Im on my cbr and I think the clubmans will be too low for him. Just waiting for warm weather to start messing with it. Thanks guys.
I have found bars 100% straight and ones from omarsdtr.com that habe a 2" negative rise. do you think the ones that have the negative rise and slight pull back give more comfort to take some pressure off your hands?
i made mine to have some pull back. basically when my arms are straight out the bars fit in to my fists without turning my wrists at all. no comfort problems for me. having completely straight ones seemed like it might get uncomfortable.
I have used straight bars, with no pullback before. They are also referred to as "Broomstick Bars". Some like them, I found them uncomfortable and they hurt my wrists...I run drag bars on most of my bikes and am fond of the "Euro Bars" also. They commonly have some pullback and about two inches of rise give or take...
