Drill Press Hot Up Options
neevo
Over 1,000 Posts
I bought a cheap drill press a while ago when I was fitting out my shed and I've used it loads of times, however there are a few issues with it:
1) The pulley above the chuck has a broken spindle mount at the bottom, meaning when I use the full travel of the press, the pulley jumps off the spindle
2) The motor is feable
3) The on switch is damaged and probably a little dangerous
I was looking for replacement pulleys but cannot seem to find anything with the same pattern so I was thinking of ways to overcome all I have and end up with a solid tool that works well.
I wan thining of replacing the motor with a variable DC motor which I assume I could attach directly to the chuck spindle, this would remove the pulleys, and also replace the switch with a variable one. Thoughts?
What else should I consider when looking to hot up my drill press?
Find an older used floor model drill press and forget about modifying the one you've got.
OK, so direct drives and variable motors may not be the option but I'm still keen to fix the pulley and look for a more torquey motor if possible.
Here is the broken pulley, you can see where the metal bit has broken off, limiting how far down you can use the drill press:
Here is the spindle:
I've tried looking for a replacement pulley but not had much luck, I would be prepared to replace the chuck if required but assume I would then need to replace both pulleys.
I'm also looking for a motor with more go. This works fine for small bits (6mm) but anything 9mm or over really struggles, even when I drill in stages. What sort of motor should I be looking for? Here is the original:
