DTT bike info database
Feed_Sparky
Active Member
I'm thinking we should start a battery thread and make it a sticky... There have been so many posts like "will this battery work in my bike?" and "how big of a battery do I need?" recently.
It could go like something like this -
Make and model of bike
Battery voltage and amp hours
Battery make and model number
What electrical stuff you have running with said battery
Electric start or no electric start.
Think it's a good idea?
Re: Battery thread idea...
It is a good idea. If we wanted to get dorky I was thinking we could make a google docs spread sheet with that info plus things like
Bike --- Year --- Carbs --- Jets --- Pipes --- Elevation --- EtC --- EtC --- Battery
We could put tons of info, anyone could see it and add their bike and it'd be easy to search.
This is a fantastic idea.
Here's an idea. How would you change it?
https://spreadsheets.google.com/ccc?key=0AvasPHbZ1Pe0dF8tNEp0LTRKTUlRQjU0UW9nLVdubmc&hl=en&authkey=CMvP7cEJ
Add what type of air filter they're running.
Good call!
Can someone try entering their own info into it to see if it works? Remember to click save.
Great idea! The sparky info helps those like me, who are electronicaly challenged. And the jet info helps the youngsters who are carberator challenged. How about adding tires and shocks/fork mods too? ;)
Feed_Sparky said:
Great idea with the spreadsheet. I tried to enter some info but it wouldn't let me.
Ok, let me work on it a bit. Keep the ideas coming.
Feed_Sparky said:
It worked!
Awesome!
Ok, before we enter more info I want input from everyone about exactly what info should be in the spreadsheet, so give me your ideas.
So a couple of questions:
1) are people interested in contributing to this database?
2) Would it be helpful?
3) What else should we include?
3a) Performance mods?
3b) Gearing/sprocket size?
Let me know. I think this could be super valuable and easy to reference.
Ethan
genius idea! we need to back up copies at time though, otherwise someone could go ahead and delete it all!
hmm... dont want TOO much on there as it could get crowded...
i would change "jets" to "jetting" as needle position etc need to be on there...
also at the end i would put "owner" and their username here so we can contact each other for more info...
suspension section
brake section (simple "front" "rear")
Ignition system (points, electric, coil type, etc.)
that should be sufficient. I can't seem to edit it... Id post some stuff if i could!
oh, and a simple "NOTES" at the end for stuff like "NOT IN PERFECT STATE OF TUNE" etc.
AMAZING IDEA! :D
Thanks Rocan, good ideas. It's locked right now so I can get a better idea of what should be in the database before we start filling it in. Also I can set it to automatically download at intervals to my comp so if it does get F'd with I can just reload the previous version.
I think this could be super helpful.
also we should look over all the entries periodically just in case we notice anything way wrong, like someone saying a stock cb350 with mikuni vm30s needs 240 size main jets. :D
Hey guys, we're still collecting information. If you'd like to add I think it could be really cool!
Thanks
-E
