Dual Mikuni VM20s choke examples on a Honda CB?
odin836
Active Member
I'm looking to replace the carbs on my 1974 Honda CB200, seems most here use the Mikuni VM20s on the CB175/CB200.
I've read on the forums that 17.5 pilot and 135 mains should do the trick...
Other than the Carbs and replacement jets what else is needed? Some sort of solution for choke and throttle?
Can anyone provide examples and whats the best source for the Carbs and parts? - BikeBandit?
Thanks!
url]
The jetting will be dependent on the bike, so only use those sizes as a guide. Bikebandit does have the best prices that I've seen. The throttle cable bolts right up and you can reach the choke lever fairly easily. The only thing i will point out is the mounting flanges ; you will probably need to have new ones made.
Cool, so I can still use the factory choke leaver to pull the chock on both carbs in sync?
No need to buy additional adapters from Mikuni?
No, but the choke on the vm20's is basically on or off. And once the motor is tuned well, you won't even need the choke too often.
by mounting flanges, do you mean the rubber manifold boots, or is there something different on the cb200?
