dull chrome and carb help
iSack1L
Does anyone know the best way (if its even possible) to get rid of the dull/scratchy look that steel whool leaves behind when using it for rust removal?
Also, can someone link me to a guide for disassembly, cleaning, and reassembly of carbs with the lemon juice method? My float bowls and jets seem in good shape, so I just want to clear them up and make sure. Wasn't planning on getting a rebuild kit or anything. Thanks.
Lastly, can someone recommend a good solvent/cleaner for the engine (e.g. fins, etc.) and also for the sprocket (real nasty grease).
Thanks again.
Simple green is a good cleaner for grease and it is good for the enviornment, but also those engine degreaser spray cans work pretty well with a wire brush
I can't offer much on the degreasing of the engine and carbs, but for the steel wool bit, I'd try some simichrome. It's available at most bike shops for about 9$ a tube. A little goes a LONG way with that stuff. I use it at work in a injection mold shop, we polish mold surfaces, and use it to lighten texture on sandblasted surfaces and add a little glow to it. For a high polish, use it with cotton balls or soft cotton cloths. Hope that helps?
