dumb timing advance question
raptormeat
so i see a lot of people saying its possible to get the cb360 timing advancer 180 degrees out?
i dont understand how this is possible given the fact the cam has a little bump and the advancer has a little notch for said bump to fit into.
im taking my top end apart again and just want to make sure im not missing any info on reassembling the advance correctly?
It can be done... If I remember right, the cam can be installed backward on the bushing, the bushing has the alignment hole. To check, use a continuity meter and make sure the cylinder is tdc on the compression stroke when it opens, to make sure, open the intake tappet cover and feel for the intake valve opening and closing.
Not a dumb question at all. The issue is that the timing unit is actually two separate pieces and the cam can be installed two ways (180* out from each other). If the bike ran before disassembly and you never took it apart you should be good. If you want to take it apart for cleaning, best to mark it so you don't need to guess or anything.
