yes correct the f mark is for static timing which is fully retarded for easy starting and a smooth idle
now you MUST check it with a timing stobe light engine running and at 3000rpms + if it falls between the other marks you are fine , if not, adjust it to make it so
and you really should check both pickups make sure all is spot on
