Dyna S Ignition Timing
evilaugust
I have a Dyna S ignition in my 350F and the directions for static timing say to use the advanced marks. Why is this? It's impossible to get it that far.
Did you physically rotate the advance mechanism while doing it? That's why they want you to time it to the advance marks...
Just did it a couple days ago.
Yes. Can only get it times to the single mark to the left of F. I can get it a little past, but that's all. I'm going off exactly when the light comes on. Is that right?
Have you followed the instructions that came with it to a T? Did you have the head apart? Cam out? Chain off the sprocket and put it together a tooth or two off? If you're just swapping the Dyna for points, you shouldn't have any trouble. How bout some more info.
That's where you want it at static timing. Full advance only happens around 2500 RPM. What manual are you reading? I'm looking at the Honda OEM Service Manual.
They describe doing it at 1200RPM (i.e. engine running) but at idle the timing is the same as static - i.e. not advanced. As you rev the engine the timing changes caused by the centrifugal forces on the weights that alter the orientation of the lobes hitting the points, making them fire earlier. This is when you need the Advance marks lined up.
http://www.hondacbfour.com/download/man_officina/pdf_manuali/CB350-400/CB350-400_01.pdf
Sorry - rewind - got caught up looking for the manual and forgot it was for the Dyna.
I have the same issue on a cb750. Can get it to turn but halfway between F and advances timing F. Did you have any luck? Do I have to lengthen the screw holes on the plate so it can rotate more ?
Just did mine yesterday. This little nugget of info helped.
An excerpt from Dyna's docs:
Timing Procedure
1) To time the engine statically, connect a 12 volt test light from the junction of the blue coil wires to ground (engine case). Do not disconnect the wires. Use a wrench on the advance assembly hex washer to rotate the engine.
2) Turn ignition switch on. While holding the rotor in the fully advanced position (clockwise), slowly rotate engine forward until the test ligth turns on. The right hand advance mark for cylinders 1-4 should align with the fixed mark on the engine case.
3) If the marks do not align, loosen the screws holding the DYNA S plate to the engine, and rotate it clockwise or counterclockwise, as appropriate, and retighten the screws.
4) Rotate the engine backwards until the light goes out, and repeat steps 2 and 3.
5) After 1-4 timing is verified, connect the test light to the yellow coil wire, and repeat Step 2, using the 2-3 timing marks. If it is necessary to adjust the 2-3 timing, loosen the cap screws holding the right module using allen wrench supplied with the kit; and move it clockwise or counterclockwise as appropriate, (.010 inch = 1 degree) and re-tighten screws.
6) Recheck timing and adjust as necessary using the above procedure until proper timing is verified.
7) The engine can also be timed dynamically using a stroe light in the normal manner. Use the advance marks and an engine speed of about 2500 RPM (full advance).
8) Replace timing cover and fuel tank.
Everything timed up perfect only to find out my coils are shit. :(
