I posted this in our build string but I am going to post it here again because we couldn't find a tutorial for a Cb175/200 Dyna S 1000 gold wing electronic ignition.
Installed a Dyna S on our CB200. After researching several electronic ignitions at Teazers suggestion we bought a Dyna S dc1-3 for a Honda Gl1000 the backing plate was a perfect fit and a direct swap for the points plate. It was also the best price we picked ours up for 125.00.
We removed the points and the timing advance mechanism. We removed the cam rotor from the advance mechanism.
We had to grind the back of the new rotor down about 3/8" and had to use a dremel to lengthen the channels in rotor. The new rotor "snaps" it the weight arms and make sure to check that the arms move freely as the mechanism engages.
The module on the right handles cylinders 1 and 2 so we will took off the left module and save it for when we add two more cylinders The right module provides +/- 10 degrees adjustment... .010 movement is 1 degree.
We found the hot wire going into the coil and used the splice connector provided and connected the red wires.
We bypassed the condenser since it is no longer needed and connected the yellow wire to the output of the coil.
We statically timed and fired her up. To statically time we used a test light on the output of the coil and rotated to the timing mark on the crank until it lit up and made adjustments to the plate just like you would with the points plate.
Now as Teazer said all we need to do is drill some vent holes in the cover and we will be "golden"
All 160/175/200 motors use the same "CB93" backing plate. A GL1000 Dyna will work on them all. And if you fit a 180 degree crank, you will have both modules Or keep one as a spare.
One difference between the 200 and 160 is the cam extension that the advancer fits over. IIRC the 175 & 200 is 1mm larger diameter at 11mm so it uses a different advancer.
I just ordered a Dyna and replacement coil for the CB160 project.
That looks might tasty. Almost like a PVL. Riddle sells a kit with pit bike magneto (copy of Kitaco/Mtaka but out of China) with laser cut side plate. OK for the track but what about charge coils for the street?
The Dyna S I ordered just arrived and slipped it straight onto a CB160. It needed a tiny trim from the top inside edge of the outer cover and one magnet I think I need to remove with a little heat and then shorten the rotor. I already removed the spare module and wiring and recovered the wire pair. Need to fit a new Sumitomo waterproof connector and we are good to go.
